Complex Analysis
  • Thread starter jjou
jjou
64
[SOLVED] Complex Analysis
Show that [tex]\mbox{Re}\left(\frac{Re^{i\theta}+r}{Re^{i\theta}-r}\right)=\frac{R^2-r^2}{R^2-2Rr\cos\theta+r^2}[/tex] where R is the radius of a disc.
I was able to show this for all real values of r. However, the problem doesn't specify whether r is real or complex. After expanding the left side using [tex]Re^{i\theta}=R\cos\theta+iR\sin\theta[/tex] and [tex]r=a+ib[/tex], I got
[tex]\frac{R^2-a^2-b^2}{R^2-2R(a\cos\theta+b\sin\theta)+a^2+b^2}[/tex]
which, as far as I know, is not equal to the right hand side of the above equation.
Intuitively, I also believe that this statement is not correct for non-real values of r since the LHS is a real value and the RHS has, at least, [tex]r^2[/tex] in the numerator and [tex]r^2[/tex] is, in general, not real for r not real.
Am I right in assuming this only holds for real-valued r?
Thanks. :)
Answers and Replies
jhicks
340
I can't see why r would denote a complex number considering the universal notation is z. Obviously the r's would be replaced by |r|'s in such a case and [itex]\theta[/itex] would be replaced with something like [itex]\theta + \angle r[/itex] (as you found using rectangular form).
jjou
64
Right, but the question didn't specify, so I was worried...
Is that not necessary? Is it okay to assume that r always denotes a real number?
In any case, am I correct in saying that the statement is false for non-real values of r?
Thanks.
jhicks
340
You showed it was false. Just by inspection of the numerator, [itex]r^2 \neq a^2 + b^2 = |r|^2[/itex] for complex r
jjou
64
Thanks. :)
Suggested for: Complex Analysis
  • Last Post
  • Last Post
  • Last Post
  • Last Post
