Complex Analysis: Integrate e^{\sin{z}} \cos{z} over Curve w_1 to w_2
In summary, the integral \int_{\gamma} e^{\sin{z}} \cos{z} dz, where \gamma is a smooth curve from w_1 to w_2, is path independent due to the holomorphicity of the integrand. This means that the value of the integral is only dependent on the endpoints and can be computed using the fundamental theorem of calculus.
latentcorpse
1,444
Let [itex]w_1,w_2 \in \mathbb{C}[/itex] and [itex]\gamma[/itex] be some smooth curve from [itex]w_1[/itex] to [itex]w_2[/itex].
Find [itex]\int_{\gamma} e^{\sin{z}} \cos{z} dz[/itex]
this is holomorphic on the entire copmlex plan so we can't use a residue theorem. furthermore, we can't assume [itex]\gamma[/itex] is a closed contour as we aren't told [itex]w_1=w_2[/itex] so it looks as if we're going to need to parameterise [itex]\gamma[/itex].
but we don't know what [itex]\gamma[/itex] looks like. however we do know that any two point in the copmlex plane can be joined by a finite number of horizontal and vertical lines so if we use instead of [itex]\gamma[/itex] a contour [itex]\gamma_1 \cup \gamma_2[/itex]
where [itex]\gamma_1[/itex] is horizontal and [itex]\gamma_2[/itex] is vertical. this is my thoughts so far but parameterising these was still going to be pretty difficult so i decided to check if I am on the right lines or not. any advice?
Hint: is this integral path independent? How can you tell?
well the fundamental theorem of calculus gives that
for
[itex]\gamma:[a,b] \rightarrow U[/itex] with [itex]\gamma(a)=\alpha,\gamma(b)=\beta[/itex]
and [itex]f: U \rightarrow \mathbb{C}[/itex] holomorphic on the open set U then, if [itex]\exists F'=f[/itex],
[itex]\int_{\gamma} f(z) dz = \int_{\gamma} F'(z) dz = \int_a^b F'(\gamma(t)) \gamma'(t) dt = \int_a^b (F \cdot \gamma(t))' dt = F \cdot \gamma(b) - F \cdot \gamma(a) = F(\beta)- F(\alpha)[/itex]
i.e. if we can find such an F, the integral will depend only on the end point values and will therefore be path independent
for our case [itex]F=e^{\sin{z}}[/itex] is such an F and so the answer is
[itex]\int_{\gamma} e^{\sin{z}} \cos{z} dz = e^{\sin{w_2}} - e^{\sin{w_1}}=e^{\sin{w_2}-\sin{w_1}}[/itex]
is that ok?
is there an easier way to tell its path independent?
also, can you recommend a good book that has plenty of worked exapmles on integrals like this (and stuff using Cauchy residue theorem etc)?
also, how did you realize to argue about path independence?
A holomorphic function defined on [tex]\mathbb{C}[/tex] always has an antiderivative (for example compute the Taylor series and integrate each term).
As you pointed out, existence of an antiderivate implies independence of path for the integral.
More generally, suppose [tex]f:D\to\mathbb{C}[/tex] is a holomorphic function and [tex]\alpha, \beta[/tex] are paths with the same endpoints. If [tex]\alpha[/tex] can be continuously deformed in D into [tex]\beta[/tex] while keeping the endpoints fixed, then the integral of f over the two paths is the same. This follows easily from Cauchy's integral theorem.
is that ok?
Aside from your final answer being in grievous error...sure:wink:
Like yyat said, whenever the integrand is holomorphic, the integral is path independent.
The question wouldn't have made much sense if the integral depended on the path now would it?
yeah. the final answer step was a BAD mistake.
surely then we could answer by this means for any given function but here it's particularly useful because we were given no information about the path itself other than the endpoints
1. What is Complex Analysis?
Complex Analysis is a branch of mathematics that deals with the study of functions of complex variables. It is based on the theory of complex numbers, which are numbers that have both real and imaginary parts.
2. What is an integral?
An integral is a mathematical concept that represents the area under a curve in a graph. It is a way of calculating the total value of a function over a given interval.
3. What is e^{\sin{z}} \cos{z}?
e^{\sin{z}} \cos{z} is a complex function that involves the exponential and trigonometric functions. It is a common function used in Complex Analysis, and it represents the product of the exponential function of the sine of z and the cosine of z.
4. What does it mean to integrate over a curve?
Integrating over a curve means calculating the integral of a function over a specific path or curve in the complex plane. This is typically done by breaking the curve into smaller segments and using techniques like the Fundamental Theorem of Calculus.
5. How do you solve the integral of e^{\sin{z}} \cos{z} over Curve w_1 to w_2?
To solve this integral, you will need to use the techniques of Complex Analysis, such as Cauchy's Integral Theorem and the Residue Theorem. These techniques involve evaluating the function at certain points and using complex contour integrals to calculate the integral over the given curve w_1 to w_2.
