• Support PF! Buy your school textbooks, materials and every day products Here!
Complex analysis
  • Thread starter KNUCK7ES
compute
I=∫_2^∞ (1/(x(x-2)^.5)) dx
using the calculus of residues. be sure to choose an appropriate contour and to explain what happens on each part of that contour.
transform to a complex integral
I= ∮ (1/(z(z-2)^.5)) dz
i don't even know where to really begin. i keep ending up dividing by zero
Answers and Replies
53
compute
First make sure you have it clearly expressed as in:
[tex]\int_2^{\infty}\frac{dx}{x\sqrt{x-2}}[/tex]
So how about use a key-hole contour that begins above the real-axis at x=2, travels down it to infinity, loops all the way round to right below the real axis at infinity, travles down the axis to 2 again, then loops around 2. That's a closed contour and I'll write the contour integral around that as:
[tex]\mathop\oint\limits_{K}\frac{dz}{z\sqrt{z-2}}[/tex]
Now, can you analyze the integral over each leg of that contour (I count 4 distinct legs, two horizontal ones, that big circular one, and that real small one around 2). Keep in mind that the horizontal legs are over a branch-cut of the square root function so on top, it's one value of the branch say [itex]\sqrt{z-2}[/itex] and on bottom, it's the other value, [itex]-\sqrt{z-2}[/itex].
ok i did so, so it the contour breaks up into for parts, Jo + JI + Jtop+ Jbottom where Jo means the outer part of the contour and JI is the inner part to the contour. Jo=JI=0. now i just do the calculus of residues on the Jtop and Jbottom, whic are
[itex]\int\frac{1}{x\sqrt{x-2}} dx[/itex]
and
[itex]\int\frac{-1}{x\sqrt{x-2}} dx[/itex]
this since the bounds are flipped, the negative sign can be cancelled and the bounds are the same allowing me to add them,
2[itex]\int\frac{1}{x\sqrt{x-2}} dx[/itex]
i know that there is only one sing. in my contour which is z= 0. so
2[itex]\int\frac{1}{x\sqrt{x-2}} dx[/itex]=2*pi*i Ʃ residues
residue= lim[itex]z\rightarrow 0[/itex] [itex]\frac{2}{\sqrt{z^{2}-2}}[/itex]
thanks btw
Related Threads for: Complex analysis
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
