I Complex coefficients in QM
781
36
Ok. I will try to do my best to explain you what is my doubt. I'm not a native English Speaker and the book I was reading is not in English Lang, but I've translated it to English.
In a spin-1/2 Stern Gerlach-like experiment, we can express the ket representing the spin component of the electrons in one direction as a linear combination of the ket spin components in z direction (z choosen to be standard basis), by multiplying them by a coefficient and summing the terms. My book says each coefficient is complex and thus have an amplitude and phase. Ok. To express the spin component in x direction, my book says, choose the phase angle to be zero for both coefficients: "we are free to choose the value of the phase. This freedom comes from the fact that we have required only that the x-axis be perpendicular to the z-axis, which limits the x-axis only to a plane rather than to a unique direction.".
I dont understand this reasoning. I thought the phase angle of complex numbers were just a form of locate them in a complex plane, but according to the book that angle determines direction (in this case, the direction along the spin component is alligned to).
Having doing that, they derived the spin component in y direction as follows:
"having arbitrarily choosen the phase to be zero for the x states, we are no longer free to make that same choice for the y states.
After they derived the equations, they founded the angle to be ± π/2 and come to their conclusion:
"The two choices for the phase correspond to the two possibilities for the direction of the y-axis relative to the already determined x- and z-axes."
So what can I conclude about all those things? Phase angle of a complex number determine its direction in 3 dimensional space as well its location in the complex plane? Can we represent both complex plane and "cartesian plane" of x,y,z-direction together? How could the direction of a spin component be determined only by a coefficient?
9,107
What do you mean by "location"? Spin has a direction only. The particle has a location but that is irrelevant in this context.
The phase difference between the two z-components determines the orientation in the x-y-plane. You can freely choose how to call the direction of 0 phase difference as this 0 is arbitrary.
781
36
Thanks for the answer. By location I mean the coordinates of the complex number written in polar form, for example the location of z = 1 (cos(θ) + i sin(θ)) is (1, θ).
33,385
9,107
Well, the value of a complex number determines where it is in the complex plane, sure. That complex plane is not associated to spatial directions.
781
36
33,385
9,107
The same thing I said in post #2, probably.
stevendaryl
Staff Emeritus
Insights Author
8,400
2,573
I'm not sure I understand how much of the following is purely conventional (that is, depending on somewhat arbitrary choices), but a pretty standard way to represent a spin-1/2 particle's spin state is this:
For a particle that is spin-up in direction [itex]\vec{r}[/itex], write [itex]\vec{r}[/itex] in polar coordinates:
[itex]r_x = r sin(\theta) cos(\phi)[/itex]
[itex]r_y = r sin(\theta) sin(\phi)[/itex]
[itex]r_z = r cos(\theta)[/itex]
Then the spin state for spin-up in direction [itex]\vec{r}[/itex] is given by:
[itex]|\psi\rangle = cos(\frac{\theta}{2}) e^{-i \frac{\phi}{2}} |U\rangle + sin(\frac{\theta}{2}) e^{+i \frac{\phi}{2}} |D\rangle[/itex]
where [itex]|U\rangle[/itex] and [itex]|D\rangle[/itex] are the states corresponding to spin-up and spin-down in the z-direction. So the phase of the coefficients determines the angle [itex]\phi[/itex], while the modulus determines the angle [itex]\theta[/itex].
781
36
Thanks. Can you show your work in relating phase angle of the coefficients with the angles of direction that describes [itex]\vec{r}[/itex]?
stevendaryl
Staff Emeritus
Insights Author
8,400
2,573
I'm not sure what's the shortest, simplest path to this answer. Define the following matrices:
  • [itex]|U_z\rangle = \left( \begin{array}\\ 1 \\ 0 \end{array} \right)[/itex] (meaning the state with spin-up in the z-direction)
  • [itex]|D_z\rangle = \left( \begin{array}\\ 0 \\ 1 \end{array} \right)[/itex] (meaning the state with spin-down in the z-direction)
  • [itex]\sigma_z = \left( \begin{array}\\ 1 & 0 \\ 0 & -1 \end{array} \right)[/itex]
  • [itex]\sigma_x = \left( \begin{array}\\ 0 & 1 \\ 1 & 0 \end{array} \right)[/itex]
  • [itex]\sigma_y = \left( \begin{array}\\ 0 & -i \\ i & 0 \end{array} \right)[/itex]
Then a state that is spin-up in direction [itex]\vec{r}[/itex] (a unit vector, meaning that [itex](r_x)^2 + (r_y)^2 + (r_z)^2 = 1[/itex]) satisfies the eigenvalue equation:
[itex]\vec{\sigma} \cdot \vec{r} \left( \begin{array}\\ \alpha \\ \beta \end{array} \right) = \left( \begin{array}\\ \alpha \\ \beta \end{array} \right)[/itex]
where [itex]\vec{\sigma} \cdot \vec{r} = \sigma_x r_x + \sigma_y r_y + \sigma_z r_z = \left( \begin{array}\\ r_z & r_x - i r_y \\ r_x + i r_y & - r_z \end{array} \right)[/itex]
In polar coordinates, [itex]\vec{\sigma} \cdot \vec{r} = \left( \begin{array}\\ cos(\theta) & e^{-i \phi} sin(\theta) \\ e^{i \phi} sin(\theta) & - cos(\theta) \end{array} \right)[/itex]. So that eigenvalue equation implies:
[itex]\alpha cos(\theta) + \beta e^{-i\phi} sin(\theta) = \alpha[/itex]
or
[itex]\alpha (cos(\theta)-1) + \beta e^{-i\phi} sin(\theta) = 0[/itex]
Using the half-angle formula, [itex]cos(\theta)-1 = -2 sin^2(\frac{\theta}{2})[/itex], and [itex]sin(\theta) = 2 sin(\frac{\theta}{2}) cos(\frac{\theta}{2})[/itex], so we can write the eigenvalue equation as:
[itex]2 sin(\frac{\theta}{2}) e^{-i \frac{\phi}{2}} (-\alpha sin(\frac{\theta}{2}) e^{+i\frac{\phi}{2}}+ \beta e^{-i\frac{\phi}{2}} cos(\frac{\theta}{2})) = 0[/itex]
where I factored out [itex]2 sin(\frac{\theta}{2}) e^{-i \frac{\phi}{2}}[/itex] to make the answer obvious. Clearly a solution to the above equation is: [itex]\alpha = cos(\frac{\theta}{2}) e^{-i \frac{\phi}{2}}[/itex] and [itex]\beta = sin(\frac{\theta}{2}) e^{+i \frac{\phi}{2}}[/itex]
781
36
or
Thank you!
Want to reply to this thread?
"Complex coefficients in QM" You must log in or register to reply here.
Related Threads for: Complex coefficients in QM
  • Posted
7 8 9
10K
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
