Complex definite integral.
In summary: It is not necessary for the metric space of the domain and range to be the same as the metric space of the function. In summary, We are discussing complex integration and the confusion about the metric space used for the domain and range of continuous functions. The definition of continuity is also mentioned, as well as the possibility of defining piecewise continuous functions for complex valued functions of real variable.
gotjrgkr
90
I've been studying complex analysis. In the part of complex integration, there is no reference about the metric space which a continuous function takes as its domain and range. So, i felt confused.
Before asking my question, i use the definition of continuity as follows
[tex]\rightarrow[/tex]
According to the text "principles of mathematical analysis" by walter rudin,
continuity is defined as follows :
Let X, Y be metric spaces. Let E be a subset of X.
Then a function f mapping E into Y( that is, f: E ⊆ X → Y ) is said to be continuous at x ∊ E if for every [tex]\epsilon[/tex] > 0, there is a [tex]\delta[/tex] > 0 such that d[tex]_{X}[/tex](x,p)<[tex]\delta[/tex] and p [tex]\in[/tex] E [tex]\rightarrow[/tex] d[tex]_{Y}[/tex]((f(x),f(p))<[tex]\epsilon[/tex].
To define complex integration, we must first define the definite integral of the complex valued function F of real variable on the interval [a,b] ; F : [a,b][tex]\subseteq[/tex]X [tex]\rightarrow[/tex] C by F(t) = U(t)+iV(t) where C is the set of all complex numbers and U and V are real valued functions of real variable which is continuous on [a,b].
In this expression, Y = C and E = [a,b]. Then what is X? is X the set of the whole complex numbers or a subset {(a,0): a is a real} of C?
and it is written that the functions U and V are real valued functions of real variable which is continuous on [a,b]. what is their metric spaces of the domain and the range of the functions U and V? are they C or {(a,0}: a is real} ?
Let R* = {(a,0): a is real}.
I've learned that for a real valued function U of real variable ( U : [a,b]⊆ R* [tex]\rightarrow[/tex] R* ), piecewise continuous can be defined. Is it also possible to define piecewise continuous about the above complex valued function F of real variable?? If so, then what is it?
In answer to your question, X is the set of real numbers R*. The metric space for the domain and range of the functions U and V is also R*. It is possible to define piecewise continuous functions of a complex valued function F of real variable. A piecewise continuous function of a complex valued function F of real variable is a function that is continuous on each part of its domain, but may have discontinuities at certain points in its domain.
1. What is a complex definite integral?
A complex definite integral is a mathematical concept used to find the area under a curve in the complex plane. It is similar to a regular definite integral, but instead of integrating over a real interval, it integrates over a complex interval.
2. How is a complex definite integral different from a regular definite integral?
A complex definite integral involves integrating over a curve in the complex plane, while a regular definite integral involves integrating over a real interval. Additionally, the complex definite integral can yield a complex number as the result, while the regular definite integral yields a real number.
3. What is the importance of complex definite integrals in science?
Complex definite integrals are important in science because they allow us to calculate quantities such as electric fields and quantum mechanical wavefunctions, which are described by complex-valued functions. They also have applications in fields such as fluid dynamics and signal processing.
4. How is a complex definite integral evaluated?
A complex definite integral is evaluated using techniques such as contour integration, where the integral is transformed into an integral over a closed curve in the complex plane. This allows us to use the powerful tools of complex analysis to evaluate the integral.
5. What are some common mistakes when working with complex definite integrals?
Some common mistakes when working with complex definite integrals include not properly understanding the difference between a complex and a real interval, not correctly applying the appropriate integration techniques, and not taking into account the possibility of a complex result.
