How Can I Solve This Complex Equation?
  • Thread starter tiwai016
  • Tags
    Complex
In summary, a person is seeking help with solving an equation they have come up with. They have tried solving it using different methods but have not been able to get the same answer. They are asking for clarification and guidance on what topic in math to use to solve the equation. The conversation suggests that simple algebra is all that is needed to solve the equation. The person is also asked to show what they have done so far to better understand their approach.
tiwai016
hi everyone,
I just thought of an equation and try to solve it , the equation is 3(y)-4(x)=2(y-2)+3(x+y/3).
the answers I have had so far of both equations are not the same, can someone help me out,
I have a questions , what steps under what topic in math can be used to solve the equation
Mathematics news on Phys.org
After a bit of algebra, you have one equation in two unknowns. You can't solve for the unknowns unless you think up another equation.
You need to clarify what you are talking about. You displayed one equation and are asking about two equations.
Show what you have done - it would us understand what you are trying to do.
All that is needed it simple algebra. What you have written is true for all y and x=4/7.
Show us what you are doing.
There are a few steps and topics in math that can be used to solve this complex equation. First, you can start by simplifying the equation by combining like terms on both sides. This will give you a simpler equation to work with. Next, you can use the distributive property to expand the parentheses on both sides of the equation. This will give you an equation with fewer variables.
From there, you can use algebraic techniques such as adding or subtracting terms on both sides, isolating variables, and using the properties of equality to solve for the unknown variable. It may also be helpful to use a graphing calculator or software to visualize the equation and find possible solutions.
Other topics that may be helpful in solving this equation include linear equations, systems of equations, and properties of operations. It may also be useful to review basic algebraic rules and concepts, such as the order of operations and the properties of real numbers.
Overall, solving complex equations requires a combination of skills, techniques, and knowledge from various areas of mathematics. It may take some trial and error, but with patience and persistence, you will be able to find the correct solution. Good luck!
What is a complex equation?
A complex equation is an algebraic equation that involves complex numbers, which are numbers that include both a real and imaginary component. It typically contains variables, constants, and mathematical operations such as addition, subtraction, multiplication, and division.
Why are complex equations important?
Complex equations are important because they have a wide range of applications in various fields of science, including physics, engineering, and mathematics. They are used to model and solve complex systems and phenomena that cannot be described using simple equations.
What is the difference between a real and complex equation?
A real equation only involves real numbers, while a complex equation involves complex numbers. Additionally, complex equations have a wider range of solutions, including both real and imaginary solutions, while real equations only have real solutions.
How do you solve a complex equation?
To solve a complex equation, you must first simplify it by combining like terms and using algebraic operations to isolate the variable on one side of the equation. Then, you can use various methods such as factoring, quadratic formula, or completing the square to solve for the variable.
What are some common applications of complex equations?
Complex equations have many applications in science and engineering, such as in electrical circuits, fluid dynamics, and quantum mechanics. They are also used in economics, finance, and computer science for modeling and analyzing complex systems.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
