Homework Help: Complex integral
  1. Sep 11, 2010 #1
    I need to solve:
    [tex]\int_{-\infty}^{\infty}xe^{(a-x)^2}dx[/tex]
    2. Relevant equations
    3. The attempt at a solution
    My first intuition would be to rewrite this as:
    [tex]\oint_cze^{(a-z)^2}dz[/tex]
    and then use Cauchy's Residue theorem to calculate the integral. There is one singularity at [itex]x_o=0[/itex] when [itex]x[/itex]->[itex]\infty[/itex]. To calculate the residue,
    [tex]Res(z_o)=(z-z_o)f(z) |_{z=z_o}[/tex]
    where in this case
    [tex]f(z)=ze^{(a-x)^2}[/tex]
    So, we have
    [tex]Res(0)=(z-0)ze^{(a-z)^2}|_{z=0}[/tex]
    [tex]=0[/tex]
    which is clearly not right (mathematica gives [itex]a\sqrt{\pi}[/itex]. What am I doing wrong? Any hints? Thanks!
    EDIT: if you take the derivative of the residue twice and then taking the limit you get [itex]2e^{-a^2}[/itex], and multiplying this by [itex]2\pi i[/itex] still doesn't give the answer!!
  3. Sep 11, 2010 #2
    hunt_mat
    No, the solution is much simplier. Make the substitution u=a-x, then note that:
    [tex]
    \frac{d}{dx}\left(\frac{1}{2}e^{x^{2}}\right) =xe^{x^{2}}
    [/tex]
  4. Sep 11, 2010 #3
    hunt_mat
    Just thought, did you mean to write:
    [tex]
    \int_{-\infty}^{\infty}xe^{-(a-x)^{2}}
    [/tex]
    as the integral you wrote down was unbounded
  5. Sep 11, 2010 #4
    Yes isn't that what I had? I am supposed to integrate it over the complex plane, this is what the problem asks and I won't get credit if I do it any other way.
  6. Sep 11, 2010 #5
    hunt_mat
    Right, what are the poles? What contour are you going to integrate it over?
  7. Sep 11, 2010 #6
    There's only one pole right? At [itex]x->\infty[/itex]?
    Typically I would integrate over the upper hemisphere.
  8. Sep 12, 2010 #7
    hunt_mat
    The problem for the residues is that the integrand is well defined for all values of x (and hence z), So I think that you're going to have to do a Laurent series expansion about z=infinty and work the residues from there.
  9. Sep 12, 2010 #8
    I am not seeing how to do this.. my math methods books don't seem to be of much help. Can you recommend some literature specific to this?
    thanks for your help by the way!
  10. Sep 12, 2010 #9
    hunt_mat
    Hmm, The problem here is the integral screams not to be done via complesx analysis.
  11. Sep 12, 2010 #10
    hunt_mat
    Try looking at the Laurent expansion about infinity, I.e. expand in a series in z^{-1} and find the coefficent of z^{-1} by the usual method and that should be your residue.
  12. Sep 12, 2010 #11
    Wrong.
