Complex integral
  1. Nov 21, 2013 #1
    I have an integral of the form:
    0exp(ax+ibx)/x dx
    What is the general method for solving an integral of this kind.
    2. Relevant equations
    Maybe residual calculus?
    3. The attempt at a solution
  3. Nov 21, 2013 #2
    Residues sound like the only way. However, make sure you are using ##e^{-z}/z##; with a positive exponent your integral will not converge.
  4. Nov 21, 2013 #3
    Dick
    I don't see how it's going to converge no matter what a is. It's also divergent near x=0.
  5. Nov 21, 2013 #4
    So true. Wish I had read the lower limit as 0 instead of 1. Can I blame it on bad eyesight?
  6. Nov 22, 2013 #5
    I need it to converge badly. But I know what mistake I made. I wanted the integral to be the imaginary part of the above. At least I think so. I have attached the whole exercise now as pdf. Is it correct what I have done so far and how do I evaluate the integral?
    • FT.pdf
      FT.pdf
      File size:
      69.3 KB
      381
  7. Nov 22, 2013 #6
    Ray Vickson
    It all looks incorrect. You wanted to integrate something like ##\exp(-cr)/r \, \exp(ikr\ cos(\theta))## over ##R^3## in spherical corrdinates. The volume element in spherical coordinates is not ##dr \, d\theta \, d\phi##; it is ##r^2 \sin(\theta)\, dr \, d \theta \, d \phi##.
  8. Nov 23, 2013 #7
    Right, I wrote that in a rush I can see. So basically I forgot the sin(theta) in the first line but it should be there or I couldnt make the substitution dcos(theta). Also the r^2 should be there and 1/r I forgot too so I would end up with having to integrate the imaginary part of r times the expression on the last line. But still with that, I don't see how I can solve that integral.
  9. Nov 23, 2013 #8
    Ray Vickson
    Your final integral is "elementary" and is the type of thing you learned to do in Calculus 101. Look at it again.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Complex integral
  1. Complex Integration (Replies: 3)
  2. Complex integrals (Replies: 5)
  3. Complex integration (Replies: 1)
  4. Complex integration (Replies: 3)
  5. Complex integration (Replies: 6)
Loading...
