Calculate Limit: $\frac{\sqrt{z}-i+\sqrt{z+1}}{\sqrt{z^2-1}}$
  • Thread starter jjr
  • Tags
    Limit
In summary, the limit of the given expression as z approaches -1 is equal to 1/(i*sqrt(2)) using the chosen branch of root where sqrt(-1)=i. This can be found by multiplying the expression by sqrt(z+i)/sqrt(z+i) and then simplifying the resulting expression.
jjr
51
Calculate the following limit if it exists
## lim_{z\to -1}\frac{\sqrt{z}-i+\sqrt{z+1}}{\sqrt{z^2-1}} ##
the branch of root is chosen to that ##\sqrt{-1}=i##
3. The Attempt at a Solution
[/B]
By inserting ##z=-1## directly, I get a ##\frac{0}{0}## expression.
I don't see how the expression can be simplified before inserting the limit, that seems out of the question.
I have a few theorems involving points at infinity, but none of them apply here.
I considered making the denominator real by multiplying by its complex conjugate, but the numerator will still be 0 when multiplied by any number.
The answer is supposed to be ##1/(i\sqrt{2})##.
Not looking for a solution or quick fix, would be very happy if someone could help me the first step of the way.J
[/B]
Hint: Try multiplying the expression by: ##\frac { \sqrt { z + i } }{ \sqrt { z + i } } ##
Moderator note: I revised the expression above to convey what FaroukYasser meant, but did not write.
Likes jjr
Thank you, got it now!
## \lim_{i\to -1} \frac{\sqrt{z}-1+\sqrt{z+1}}{\sqrt{z^2-1}} ##
##\to \lim_{i\to -1} \frac{\sqrt{z}-1+\sqrt{z+1}}{\sqrt{(z+1)(z-1)}} ##
##\to \lim_{i\to -1} \frac{1}{\sqrt{z-1}} = \frac{1}{i\sqrt{2}} ##
[/B]
Is your numerator equal to ##\sqrt{z} \: - i \: + \sqrt{z+1}##, or is it ##\sqrt{z-i} + \sqrt{z+1}## (or maybe even ##\sqrt{z-i} + \sqrt{z+i}## )? You wrote the first.
The first
1. What is the limit of the given expression as z approaches infinity?
The limit as z approaches infinity is 0.
2. What is the limit of the given expression as z approaches -1?
The limit as z approaches -1 is undefined.
3. How do you simplify the expression before taking the limit?
To simplify the expression, you can multiply both the numerator and denominator by the conjugate of the numerator. In this case, the conjugate is $\sqrt{z}+i-\sqrt{z+1}$.
4. Can this limit be evaluated using L'Hopital's rule?
Yes, L'Hopital's rule can be used to evaluate this limit. However, it may be easier to simplify the expression first before using L'Hopital's rule.
5. How can this limit be applied in real-world situations?
This limit can be used in various mathematical and scientific fields to solve problems involving rates of change, such as in calculus and physics. It can also be used in machine learning and data analysis to optimize algorithms and models.
