Complex Locus - PLEASE HELP
Complex Locus - PLEASE HELP!!!!!!!!!!
Q1: The complex number z satisfies arg(z+3) = pi/3
(a) Sketch the locus of the point P in the Argand diagram which represents z (DONE)
(b) Find the modulus and argument of z when z takes its least value. (STUCK)
(c) Hence represent z in a + ib form. (STUCK)
arg(z+3) = pi/3
arctan[y/(x+3)] = pi/3
y/(x+3) = sqrt(3)
y = sqrt(3)x + 3*sqrt(3)
I can't do part (b) and hence (c) of Q1.
__________________________________________________________________
Q2: If z is any complex number such that |z| = 1, show using Argand diagram or otherwise that:
(a) 1 <= |z+2| <= 3 (STUCK)
(b) -pi/6 <= arg(z+2) <= pi/6 (STUCK)
I have sketched both parts (a) which is the region between the circles centred at (-2,0) and radii 1 and 3 and (b).
___________________________________________________________________
Q3: The complex number z = x+iy, x and y are real, such that |z - i| = Im(z).
(a) Show that the point representing z has a Cartesian Equation y = 1/2(x^2 + 1). Sketch the locus. (DONE)
(b) Find the gradient of the tangent to this curve which passes through the origin. Hence find the set of possible values of the principal argument of z. (STUCK)
|z - i| = Im(z)
y = 1/2(x^2 + 1)
for part (a)
sqrt[x2 + (y-1)2] = y
x2 + y2 - 2y + 1 = y2
therefore, y = 1/2(x2+1)
Part (b) - NO IDEA!
Thanks for your help!!!
Answers and Replies
Fredrik
Staff Emeritus
413
There's no ordering relation on the complex numbers. Do you mean when |z| takes its least value? In that case, you have an equation of the form y=kx+m, and you know that z=x+iy. You get |z| (as a function of x) from that. Then you find the minimum by setting its derivative =0, and so on.
When it says you can use a diagram, you really just have to draw the picture and point at the details that make it obvious. If z is on the unit circle, then z+2 is on a circle with the same radius but moved 2 units to the right. So its left edge is at 1 and its right edge at 3 (because the original circle had the edges at -1 and +1). For a more rigorous solution, use the triangle inequality and the...uh...I don't know what it's called, but it's similar to the triangle inequality, but with a minus sign.
z+2 is on the circle with radius 1 centered at 2, not -2. So draw that circle, and then draw two lines from 0 that are tangent to the circle (above and below). Can you figure out the angles they make with the real axis?
Thanks Fredrik, I was actually taking 1 <= |z+2| <= 3 as the region between circles centered at (-2,0) and with radii 1 unit and 3 units.
I see where I went wrong. But just one thing, why isn't |z+2| a circle centred at (-2,0)?
Fredrik, you are absolutely correct.
Q1 (b) is supposed to read:
(b) Find the modulus and argument of z when |z| takes its least value.
What will be the value of k and m (I mean how do you obtain these)?
Fredrik
Staff Emeritus
413
|z+2| is just a number. If you're thinking of the equation |z+2|=1, it defines a circle with radius 1 centered at -2, but you were given the equation |z|=1. The problem asks you to show that the two inequalities you were given are satisfied by each z on that circle.
You already did that in your first post. I drew a picture and saw that the line forms a right triangle with the two axes. The bottom side has length 3, and the right side has length m, so
[tex]k=\frac{m}{3}=\tan\left(\frac{\pi}{3}\right)[/tex]
and therefore
[tex]y=kx+m=k(x+3)=\tan\left(\frac{\pi}{3}\right)(x+3)[/tex]
and therefore
Thanks Fredrik. Yeah it was a bit stupid of me to ask what k and m were.
Related Threads on Complex Locus - PLEASE HELP
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
