Solve for Complex Number z5= -1: Tips & Solutions for a Tricky Question
In summary: I think the idea is to infer what the product ##z_0 z_1 z_2 z_3 z_4## equals by comparing the two sides of the equation. It's a bit confusing because it doesn't seem like they want you to solve the equation for each individual term, they just want the product.
cosmictide
37
Hi guys, I have no idea what this question wants me to do. Any clarification would be appreciated.
Let z0, z1, z2, z3 and z4 be the solutions that you obtained. Use the factorization
z5+1= (z - z0) (z - z1) (z - z2) (z - z3) (z - z4)
to determine the complex number that is obtained by multiplying together all the solutions of the equation z5= -1.
These are the solutions I managed to calculate
z0= cos(pi/5) + i sin(pi/5)
z1= cos(3pi/5) + i sin(3pi/5)
z2= cos(pi) + i sin(pi)
z3= cos(7pi/5) + i sin(7pi/5)
z4= cos(9pi/5) + i sin(9pi/5)
Does the question want me to plug these in and multiply them out because there's no chance that's happening or am I missing something?
Thanks in advance. :smile:
The question is confusing to me. It sounds like they want you to multiply the solutions to get a complex number, so it does not sounds like they want you to recover the polynomial ##z^5+1 ##. In that sense you won't need that formula.
:biggrin: :biggrin:
It looks like you are on the right path. However, do you know about the complex exponential ## E^{i \theta} ##? All your solutions can be written very simply in terms of that exponential and in that case, multiplying all the roots takes one line!
Thanks for your reply. :smile:
I've only briefly come across the complex exponential. I know it expresses a complex number much more concisely but usually the questions I get asked specify if that's what they're looking for. To be honest there's nothing about how to answer the question in any of the textbooks given so I'm not sure how to approach it.
You are welcome.
The key identity is
[itex] e^{i \theta} = \cos (\theta) + i \sin(\theta) [/itex]
Now you see how each of your roots can be expressed as a single exponential.
The nice thing now is that multiplying exponentials is trivial!
nrqed said:
The question is confusing to me. It sounds like they want you to multiply the solutions to get a complex number, so it does not sounds like they want you to recover the polynomial ##z^5-1##. In that sense you won't need that formula.
nrqed, maybe you typed '-' when you meant '='. The roots of the polynomial equation z5 + 1 = 0 are the values for z0, z1, z2, z3, and z4 in the factored form.
Thanks, I actually meant ##z^5+1 ##. My mistake.
I think the idea is to infer what the product ##z_0 z_1 z_2 z_3 z_4## equals by comparing the two sides of the equation. It's a conceptual problem, not a grind-it-out problem.
Likes 1 person
Agreed, that works and is more elegant (and probably what they wanted)
Thanks guys.
I'm still not entirely sure what I need to do in respect to comparing the two sides to see what the product equals. Is there any worked examples of similar problems I can look at?
Thanks.
You can factorize a polynomial P(x) if you know the roots of the equation P(x)=0.
In case of a quadratic equation,
x2+bx+c=(x-x1)(x-x2)=0.
If you can factorize P(x) this way, x1 and x2 are the roots. Expanding the product you get x2-(x1+x2)x +x1x2.
The two sides are equivalent if the coefficients of the equal powers of x are the same at both sides.
For x2, it is true, both are 1.
The coefficient of x is b on the left side and it is -(x1+x2) on the right side, so b=-(x1+x2).
The constant term is c on the left side and (-x1)(-x2) on the right side, so c=(-x1)(-x2).
In the same way, if you have a complex polynomial of fifth order you can factorize it and the constant term must be the same of both sides.
See Vieta's Formulas http://mathworld.wolfram.com/VietasFormulas.html
Your polynomial is z5+1 and the roots of the equation z5+1=0 are z1,z2,z3,z4,z5.
z5+1=(z-z1)(z-z2)(z-z3)(z-z4)(z-z5).
When expanding the right side, all terms contain some power of z except the last, the product of the constant terms - what is that product?
It must be the same as the constant term at the left side. What do you get?
ehild
Likes 1 person
ehild
Thanks for replying. :smile:
I've not come across this before so sorry if I've completely missed the point. So is this what the question is looking?
(z+1)*(z4-z3+z2-z+1)
It is the left side. I meant the other side. If you multiplied all the 5 factors, what would be the term that contains only z1,z2, z3, z4, z5 and no z?
ehild
I don't think so. It just wants you to multiply all the roots you found. (Don't "plug them in", just take the 5 numbers and multiply them.) nrqed recommended representing the roots you found in ##e^{i \theta}## form. That will make it easier, but the result should not be surprising either.
If you expand a product (x+a)(x+b)(x+c)(x+d)(x+e) then you get a single term with x5
terms with x4: (-a-b-c-d-e)x4
terms with x3 : x3(ab+ac+ad+ae+... )
terms with x2: x2(abc+abd+abe+bcd+...)
terms with x1: x(abcd+abce+bcde+...)
at the end you have one constant term: abcde
In the problem, a, b, c, d, e are -z1, -z2, -z3, -z4, -z5.
The constant term is : ?
The constants are the same on both sides: The left side is z5+1, the constant is 1. That is equal to the constant on the right side which is ??
ehild
Multiply out the righthand side symbolically. What do you get? You should see a pattern to the coefficients, and you should see why this pattern emerges.
ehild
So is it -1? :confused:
Also, I think you are going to be getting two different responses to how to handle this.
I am answering your issue based on the fact that you have already provided a certain amount of work. You found the roots in step 3. Hence, all you have to do is multiply them together.
Others may answer your question in the more general sense. The problem statement doesn't require you to find the exact roots like you did in step 3. You could just examine the algebra provided in step a to find the answer.
Does this help?
##z^5 + 1 = (z-z_0)(z-z_1)(z-z_2)(z-z_3)(z-z_4) = z^5 -(z_0+z_1+z_2+z_3+z_4)z^4+?z^3+?z^2+?z+?##
It certainly tells you something about the sum of the roots. And perhaps you can see something about the product of the roots as well?
What is -1? :smile:If you mean the solution of the problem, yes, it is: The constant term on the right side is (-z1)*(-z2)*(-z3)*(-z4)*(-z5)= -z1z2z3z4z5=1, so the product of the roots is -1.
ehild
1. What is a complex number?
A complex number is a number that consists of a real part and an imaginary part, represented in the form a + bi, where a and b are real numbers and i is the imaginary unit (√-1).
2. How do you solve for a complex number?
To solve for a complex number, we can use the formula z = r(cos θ + i sin θ), where r is the absolute value of the complex number and θ is the angle it makes with the positive real axis. We can also use algebraic methods such as setting two complex numbers equal to each other and solving for the variables.
3. What does it mean for z5 to equal -1?
When z5 equals -1, it means that when the complex number z is raised to the fifth power, it results in -1. This is known as the fifth root of -1.
4. Can the complex number z5 = -1 have multiple solutions?
Yes, the complex number z5 = -1 can have multiple solutions. This is because raising a complex number to a power can result in multiple values, known as the complex roots.
5. How can I check if my solution for z5 = -1 is correct?
You can check if your solution for z5 = -1 is correct by plugging it back into the original equation and seeing if it satisfies the given condition. You can also use the complex number calculator to verify your solution.
