Complex Numbers ~ Locus
  1. Mar 18, 2009 #1
    Mentallic
    The curve on the Argand diagram for which
    [tex]|z-2|+|z-4|=10[/tex]
    is an ellipse. Find the co-ordinates of its centre and the lengths of its major and minor axes.
    2. Relevant equations
    [tex]z=x+iy[/tex]
    3. The attempt at a solution
    I could only find the centre by using common sense in a way: ([itex]\frac{2+4}{2}[/itex],0) = (3,0)
    No idea how to answer the second part though.
  3. Mar 18, 2009 #2
    tiny-tim
    Hi Mentallic! :smile:
    Hint: the major axis is obviously along the real axis,
    so the ends of the major axis are also, and the ends of the minor axis are on a line parallel to the imaginary axis :wink:
  4. Mar 18, 2009 #3
    HallsofIvy
    You can interpret |z- a| as the distance from z to a. An ellipse has the property that the total distance from a point on the ellipse to the two foci is a constant. In other words |z- 2|+ |z- 4|= 10 tells you that the foci of the ellipse are 2 and 4.
  5. Mar 18, 2009 #4
    Mentallic
    Yes I realized that too :smile: but the distances to these end-points...?
    If I were to take a stab at it, I'd go about it like this:
    [tex]\sqrt{(x-2)^2+y^2}+\sqrt{(x-4)^2+y^2}=10[/tex]
    where y=0 since end-points are real.
    Therefore, [tex]x-2+x-4=10[/tex]
    x=8
    So, distance 8 from centres of each modulus.
    [tex](2-8,0) = (-6,0)[/tex] and
    [tex](4+8,0) = (12,0)[/tex]
    Is this a legitimate approach?
    Similarly for the minor axes:
    x=3 since they lie on the perpendicular bisector of (2,0) and (4,0)
    Hence, [tex]\sqrt{1+y^2}+\sqrt{1+y^2}=10[/tex]
    [tex]y=\pm 2\sqrt{6}[/tex]
    So I'm guessing the minor end-points are [tex](3,2\sqrt{6}) (3,-2\sqrt{6})[/tex] ?
    Once again, this is a total guess so please correct me where I'm wrong.
  6. Mar 18, 2009 #5
    Mentallic
    So the centre of the ellipse is (3,0) and has focii at (2,0) and (4,0).
    So for the general cartesian form of an ellipse: [tex]\frac{x^2}{a^2}+\frac{y^2}{b^2}=1[/tex]
    [tex]ae=1[/tex] where e=eccentricity.
    I'm lost from here...
  7. Mar 18, 2009 #6
    tiny-tim
    (have a square-root: √ :wink:)
    Yes, and now just say "so 8 is one end of the major axis"
    … and then find the other end by using the "opposite value" of the ||s.
    (why is that a guess? :confused:)
    Yes, that's fine, except you mean 3 ±2(√6)i :smile:
  8. Mar 18, 2009 #7
    HallsofIvy
    For an ellipse, [itex]c^2= a^2- b^2[/itex] where a and b are the distances from the center to the vertices and c is the distance from the center to the focus. So you know that [itex]a^2- b^2= 1[/itex].
  9. Mar 18, 2009 #8
    Mentallic
    Thanks for the correction. I also took on a more geometric approach and found half the minor axis to be [tex]\sqrt{5^2-1}=2\sqrt{6}[/tex] through an isosceles triangle and the pythagorean theorem which supported my algebraic result.
    Sorry, but I haven't studied ellipses much at all. I remember a few general results but don't know their significance and I'm once again unsure what to do with this relationship of [itex]a^2-b^2=1[/itex]
  10. Mar 19, 2009 #9
    tiny-tim
    Start by looking at the PF Library pages on conic and eccentricity :wink:
