Exploring the 4th Roots of -16
  • Thread starter UrbanXrisis
  • Tags
    Roots
In summary, to find the 4th roots of -16, we can use the formula (-16)^{1/4}=2e^{i \pi/4} to find all four distinct roots, which are 2e^{i \pi /4}, 2e^{9i \pi /4}, 2e^{17i \pi /4}, and 2e^{25i \pi /4}. It is important to remember that the principle root of -16 is not equal to i, but rather -1, when using the formula.
UrbanXrisis
1,196
i am to find the 4th roots of -16
[tex](-16)^{1/4}=2i^{1/4}[/tex]
[tex]i=e^{i \pi/2}[/tex]
[tex]i^{1/4}=e^{i \pi/8}[/tex]
[tex](-16)^{1/4}=2e^{i \pi/8}[/tex]
or
[tex](-16)^{1/4}=2e^{i 5\pi/8}[/tex]
or
[tex](-16)^{1/4}=2e^{i 9\pi/8}[/tex]
is this correct?
As far as it goes. Where is your fourth 4th root?
the fourth root of -16 is [tex]2e^{i 9\pi/8}[/tex]
didnt i show that?
If that's the fourth 4th root, then where's your third? You've only written three roots down, so you're missing at least one of them!
I'm not sure I understand. I am to find the 4th root of -16, not the fourth 4th root. and (-16)^(1/4) is the fourth root of -16, so I'm not sure what else is needed since [tex](-16)^{1/4}=2e^{i 9\pi/8}[/tex]
In the original question, you said you're supposed to find the 4th roots of -16. As in all of them. How many 4th roots does -16 have? How many have you shown?
I guess I'm not up on the convention for this stuff, but I would say that this is wrong. I would say the L.H.S. is multivalued, and denotes all fourth roots of -16, and the R.H.S. is a single value, denoting one fourth root of -16. Thus, it wouldn't be appropriate to write an equality there.
I see, so they are equal but just not equal in showing ALL the fourth roots of -16 right?
well that's like saying sin^-1(1/2) doesn't equal pi/6, because it also equals 5pi/6 and, well, so on
I agree. Lots of silly mistakes are made because people forget that the inverse of the sin function is multivalued.
What? "they are all equal but just not equal"?
Any number has 4 distinct fourth (complex) roots. For example the fourth roots of 1 are 1, -1, i, and -i. You were asked to find all of the fourth roots of -16. ("i am to find the 4th roots of -16")
You only showed three in your original post.
Actually, your very first statement:
is wrong. The principle root of 16 is, of course, 2 but -1 is not equal to i!
What you should have written was
[tex](-16)^{1/4}= 2(-1)^{1/4}[/tex]
Now, what are the 4 distinct fourth roots of -1?
[tex](-1)^{1/4}=e^{i \pi /4}[/tex]
[tex](-1)^{1/4}=e^{9i \pi /4}[/tex]
[tex](-1)^{1/4}=e^{17i \pi /4}[/tex]
[tex](-1)^{1/4}=e^{25i \pi /4}[/tex]
right? so that:
[tex](-16)^{1/4}= 2e^{i \pi /4}[/tex]
or
[tex](-16)^{1/4}= 2e^{9i \pi /4}[/tex]
or
[tex](-16)^{1/4}= 2e^{17i \pi /4}[/tex]
or
[tex](-16)^{1/4}= 2e^{25i \pi /4}[/tex]
1. How do you find the 4th roots of -16?
To find the 4th roots of -16, you can use the formula:
x = ±√n√√n√-16
where n is the root you are trying to find (in this case, n = 4).
Therefore, the 4th roots of -16 are:
x = ±√4√√4√-16
x = ±√2√2√-16
x = ±2√-2
x = ±2i, ±2i, ±2i, ±2i
2. Is it possible to find imaginary roots for -16?
Yes, it is possible to find imaginary roots for -16. In fact, the 4th roots of -16 are all imaginary numbers (±2i, ±2i, ±2i, ±2i). This is because when taking the 4th root of a negative number, the result will always be an imaginary number.
3. Can the 4th roots of -16 be simplified?
Yes, the 4th roots of -16 can be simplified. In this case, the 4th roots of -16 are already in their simplest form, which is ±2i, ±2i, ±2i, ±2i. This is because there are no perfect 4th powers that can be taken from -16 to simplify the roots further.
4. What is the difference between the 4th roots and 4th powers of -16?
The 4th roots of -16 are the numbers that, when multiplied by themselves 4 times, result in -16. These numbers are ±2i, ±2i, ±2i, ±2i. On the other hand, the 4th powers of -16 are the numbers that result from multiplying -16 by itself 4 times. These numbers are 16, 256, 4096, etc.
5. Can the 4th roots of -16 be expressed as real numbers?
No, the 4th roots of -16 cannot be expressed as real numbers. This is because the 4th root of a negative number will always result in an imaginary number. In this case, the 4th roots of -16 are all imaginary numbers (±2i, ±2i, ±2i, ±2i).
