XtremePhysX
- 92
Find a real quadratic factor of the polynomial:
[tex]z^{4}+16=0[/tex]
I don't know :$
XtremePhysX said:Thank you guys.
-16 = 16cis(pi)
where do I go from there?
-16 = 16cis(pi)
XtremePhysX said:so I got (z^2+4i)(z^2-4i)
can I split that into linear factors?
ehild said:Have you solved the problem? What is the solution?
The more elegant method would have been to use the complex roots of -16, which are zk=2 cis[pi/4+k(2pi/4)], (k=0,1,2,3) and write z4=(z-2cis(pi/4))((z-2cis(3pi/4))((z-2cis(5pi/4))((z-2cis(7pi/4)). The product of the first and last factors is real and so is the product of the second and third ones.
ehild
XtremePhysX said:The question says this: Find a real quadratic factor of the polynomial [tex]z^{4}+16=0[/tex]
Does that mean the factors can't be imaginary, I'm a bit confused here.
XtremePhysX said:[tex] \left [ z+(2 (-1)^{1/4}) \right ] \left [ z-(2 (-1)^{1/4}) \right ] \left [ z+(2 (-1)^{3/4}) \right ] \left [ z-(2 (-1)^{3/4}) \right ] [/tex]
So this is the solution.
Mentallic said:Nowhere near. Those are linear factors, and they're not real factors either.
The question asks you to convert these complex linear factors into real quadratic factors.
Start by answering these:
[tex]cis(\pi/4)+cis(-\pi/4)=?[/tex]
[tex]cis(\pi/4)cis(-\pi/4)=?[/tex]
ehild said:Not yet, you can not use complex numbers. So substitute the roots of -1 in the form a+bi. Then multiply two factors which are complex conjugate to each other to eliminate the imaginary parts.
You know that √(-1)=±i. What is √i? What are the complex numbers which squares are i?
(hint: try cos(pi/4)+isin(pi/4))ehild
Yes, but what is it in numerical form, a+bi without cis and pi?XtremePhysX said:Isn't √i either:
[tex]e^{\frac{i\pi }{4}}[/tex]
or [tex]cis(\frac{\pi }{4})[/tex]
uart said:The best way to solve it with complex numbers is to find the 4 complex roots.
1. Note that the roots can be grouped as pairs of complex conjugates.
2. We know that both the sum and product of complex conjugates are real numbers.
3. Use the relationship between the sum and product of the roots and the coefficients of a quadratic to find the factor.
XtremePhysX said:[tex]cis(\pi/4)+cis(-\pi/4)=\sqrt{2}[/tex]
[tex]cis(\pi/4)cis(-\pi/4)=1[/tex]
XtremePhysX said:[tex]z^{2}+2z\sqrt{2}+4[/tex]
Mentallic said:[tex]z^4+16=(z-2cis(\pi/4))(z-2cis(-\pi/4))(z-2cis(3\pi/4))(z-2cis(-3\pi/4))[/tex]
ehild said:You forgot "2" in front of cis. :tongue2:
ehild
XtremePhysX said:The question says a real quadratic factor so I though that implies there should be only 1 factor. Isn't that right?
Mentallic said:Yes you're right, but I don't understand why they'd make you stop there.
ehild said:The second one is obvious: The product of the other two linear factors: z2-2√2 z+4. Check if multiplying these two factors you really get z4 +16.
ehild
XtremePhysX said:It's a 2 mark question in an MX2 paper, I think you know what MX2 is ;)
Mentallic said:Oh, well then a lot of time would've been wasted finding the other complex roots as well if only one quadratic factor is necessary. Look at how quick and easy the solution can be:
[tex]z^4+16=0[/tex]
[tex]z^4=-16[/tex]
[tex]z^4=16cis(\pi+2k\pi)[/tex]
[tex]z=2cis(\frac{\pi(1+2k)}{4})[/tex] for [itex]k=-2,-1,0,1[/itex]
Now let's just consider one of the complex conjugate pairs:
[tex]z_1=2cis(\pi/4)[/tex]
[tex]z_2=2cis(-\pi/4)=\bar{z_1}[/tex]
Therefore the quadratic factor is,
[tex](z-z_1)(z-\bar{z_1})[/tex]
[tex]=z^2-(z_1+\bar{z_1})z+z_1\bar{z_1}[/tex]
Where [tex]z_1+\bar{z_1}=2Re(z_1)=4cos(\pi/4)=2\sqrt{2}[/tex]
and [tex]z_1\bar{z_1}=4|z_1|^2=4[/tex]
Therefore we have the quadratic factor
[tex]z^2-2\sqrt{2}z+4[/tex]
To find a quadratic factor of z⁴+16, you can use the quadratic formula or factor by grouping. First, rewrite the equation as (z²)²+4². Then, you can use the quadratic formula to solve for z², which will give you the quadratic factor. Alternatively, you can group the terms (z²)² and 4² together and factor out a common term to find the quadratic factor.
No, z⁴+16 can only have one quadratic factor. This is because z⁴+16 is a polynomial of degree 4, and a quadratic factor will reduce the degree of the polynomial by 2. Therefore, there can only be one quadratic factor in z⁴+16.
To check if your quadratic factor of z⁴+16 is correct, you can use the distributive property to expand the factor and see if it simplifies back to z⁴+16. You can also plug in different values for z to see if the factor produces the same result as the original equation.
Yes, there is a shortcut for finding the quadratic factor of z⁴+16. If you know that z⁴+16 is a sum of squares, you can use the difference of squares formula to find the quadratic factor. In this case, the quadratic factor would be (z²+4)(z²-4).
Yes, you can use a calculator to find the quadratic factor of z⁴+16. Simply enter the equation into your calculator and use the appropriate function to find the quadratic factor. However, it is important to understand the steps involved in finding the quadratic factor manually in case the equation is more complex and a calculator is not available.
