Complex Numbers
  1. Feb 8, 2016 #1
    2. Relevant equations
    De Moivres Theorem/ Eulers formula
    3. The attempt at a solution
    Honestly don't know where to go with this now. I already applied De Moivres theorem at the very end. It feels like I have to do something more with either De Moivres theorem or Eulers formula. (only 2 we have done)
  3. Feb 8, 2016 #2
    Samy_A
    Start from ##a+bi-\frac{1}{a+bi}=i##, multiply both sides with ##a+bi## and work it out. That will allow you to find the value(s) of a and b. Then use De Moivre's formula to get ##z^6##.
  4. Feb 8, 2016 #3
    Where do I go form here?
  5. Feb 8, 2016 #4
    Samy_A
    On the left you have a complex number, say ##X+iY##, that is equal to 0. What can you then conclude about X and Y?
  6. Feb 8, 2016 #5
    then X and Y should be equal to 0. But I don't see where is the complex number on the left? I know b-ai is one but I'm not too sure about the 2abi thing?
  7. Feb 8, 2016 #6
    Samy_A
    Correct.
    The complex number on the left is ##a²+2abi-b²-1-ai+b=(a²-b²-1+b)+(2ab-a)i##. Your computation showed that this complex number is 0. You should be able to get the value(s) of a and b from that.
  8. Feb 8, 2016 #7
    Ah. I see now. the entire left side was a complex number. Is this correct now?
  9. Feb 8, 2016 #8
    Samy_A
    b is correct.
    But you made a sign error while computing a, so that a is not correct.
    Keep in mind that an equation in the form ##a²=c## can have two real solutions.
    Also, to be complete, you should explain why in ##2ab=a##, you reject the solution ##a=0##.
  10. Feb 8, 2016 #9
    Ah I see. Should it be a = + or - sqrt(1/4). therefore giving me two solutions for a. a = +1/4 and a = -1/4. I entered both into 2ab-a=0 and both give me true statements.
    Also would the reason for rejecting a=0 be that if a=0 it would give me no value for b either.
  11. Feb 8, 2016 #10
    Samy_A
    Any value for a will give you a true statement if b=1/2.
    No, that is still wrong. As I wrote, somewhere in the calculation you make a sign error: a minus for no reason becomes a plus.
    Correct.
  12. Feb 8, 2016 #11
    Ray Vickson
    There is no need for DeMoivre or Euler. Once you have ##z = a + ib## you can quite quickly and easily get ##z^2##, then get ##z^4 = z^2 \cdot z^2## and finally ##z^6 = z^4 \cdot z^2##.
    However, if you do care to use DeMoivre/Euler you should first examine very carefully the actual form of ##z##.
  13. Feb 8, 2016 #12
    ehild
    Multiplying the equation z+1/z=i by z, you get a quadratic equation for. Get the solution with the quadratic formula. Write z in the exponential/ trigonometric form.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Complex Numbers
  1. Complex Numbers (Replies: 2)
  2. Complex numbers (Replies: 6)
  3. Complex numbers (Replies: 6)
  4. Complex Numbers (Replies: 3)
Loading...
