Complex roots
  • Thread starter w3390
Z^5 = -1
What are the five roots?
I do not know how to start this problem. I am given a hint to put -1 into the form Ae^(i*delta), but I am unsure as to how I can do that. Any help would be much appreciated.
Answers and Replies
hunt_mat
1,741
25
Use
[tex]
e^{ix}=\cos x+i\sin x
[/tex]
Ya, I know. That was the hint I was given. However, I don't know exactly how to apply it in this situation. How do I get five roots from that equation?
hunt_mat
1,741
25
[tex]
-1=\cos x+i\sin x\Rightarrow \cos x =-1 \quad \sin x =0.
[/tex]
What could x be?
Use
[tex]
[/tex]
he could also use
z = x + iy
z^5 = x^5 ... iy^5
(fill in the rest)
to remove the theta
X could be any odd integer multiple of pi (i.e. pi, 3pi, 5pi, 7pi....). Is that what you are talking about?
hunt_mat
1,741
25
Almost, not any odd integer of pi, but a specific one.
I'm sorry. I don't see why it has to be a specific one. All of those work so how do I know which particular one is correct?
There is another way too.
[tex] r^{5}e^{5 thetha } = e^{i \pi + 2n \pi}[/tex]
This way you can get all the values of for the angle from a " formula".
So:
-1 + i*0 = cos(x) + i*sin(x)
Therefore:
cos(x) = -1
sin(x) = 0
To satisfy both these conditions, X can be any odd integer multiple of pi.
cos(n*pi) = -1 for n= 1, 3, 5, 7, ...
sin(n*pi) = 0 for n= 1, 3, 5, 7, ...
I don't see how there can be a single specific answer.
I also don't understand where I am going to get five roots from.
So:
Therefore:
cos(x) = -1
sin(x) = 0
You are correct.
[tex] cosx = -1 \Rightarrow x = \pi +2n\pi[/tex]
[tex]x = \pi +2n\pi [/tex]
Now that you have
[tex]-1 = e^{i \left(\pi + 2n \pi \right)}[/tex]
You also have [tex] r^{5}e^{i5 \theta } = e^{i \left(\pi + 2n \pi \right)}[/tex]
What is r and theta ?
[tex] r = ?[/tex]
[tex] \theta = ? [/tex]
diazona
2,175
What the other posters have been trying to guide you through is a two-step process. The first step is to find a way to express -1 in the form [itex]re^{i\theta}[/itex] - that is, what values of r and θ will make the expression [itex]re^{i\theta}[/itex] equal to -1? For this part, you use Euler's identity,
[tex]e^{i\theta} = \cos\theta + i\sin\theta[/tex]
As you have found, there is not just one solution for θ, but a whole infinite sequence.
Once you've found the value(s) of r and θ that correspond to -1, the second part of the problem will be to figure out what complex numbers to the fifth power equal -1. You can use the usual property of exponents,
[tex](a^b)^c = a^{bc}[/tex]
Since you have an infinite set of possible values for θ for -1, go through them one by one and for each one, find the complex number (in polar form) that, when raised to the fifth power, gives you your r times e for that θ. Obviously you cannot do the entire infinite sequence, but do enough of them to see the pattern.
After you're done with that, if you convert the complex numbers you found from polar form back to Cartesian form (x+ iy), you should find that there are only five different values. Those are the roots you're looking for.
Okay, thanks for the explanation diazona. However, let me show you my thought process.
So I have already found that when theta=pi, 3pi, 5pi, 7pi, ... ; e^(i*theta) will equal -1.
I also think that the only possible value for r is 1.
So then you say I need to find what complex numbers when raised to the fifth power give me -1.
So, (e^(i*theta))^5 = e^(i*5*theta).
My question is regarding the previous step. If I am to plug in all the possible values of theta (pi, 3pi, 5pi, 7pi, ...) then when I multiply by five I will still get an odd multiple of pi and it will always result in -1.
Either you don't need my help or you don't want to listen( or read) to me.
I would take the former as the case.
Actually it's neither of those. Since I don't know how to do this, I can't just look at an equation and know how to navigate my way to the final answer.
Yes, I see your equation: (r^5)(e^(i*5*theta))=-1
This works when r=1 and theta=pi so this is one solution.
This also works when r=-1 and theta=0 so this is a solution.
What I was getting at was do I need 5 unique r values and 5 unique theta values because it also works when r=-1 and theta=2pi.
Good. You get the general idea.
Look at this
So far you have deduced that
[tex] r= 1[/tex]
We see that
[tex] 1^{5}e^{i5 \theta } = e^{i \left(\pi + 2n \pi \right)}[/tex]
[tex]e^{i5 \theta } = e^{i \left(\pi + 2n \pi \right)}[/tex]
This means
[tex] 5 \theta = \pi + 2n \pi [/tex]
Can you solve for theta and then try n = 0 ,1, 2,3,4 ?
What values do you get for theta?
Actually, I forgot to point out that r is defined to be positive.
So you can't pick r = -1.
Solving for theta and plugging in n=0,1,2,3...
I get:
theta = (1/5)*pi
theta = (3/5)*pi
theta = (5/5)*pi
theta = (7/5)*pi
I get:
theta = (1/5)*pi
theta = (3/5)*pi
theta = (5/5)*pi
theta = (7/5)*pi
Correct.
You are missing n=4.
Anyway, what you have here are the arguments of complex numbers which are all roots of -1 .
These are your answers.
EDIT :
To see this
[tex] \left(e^{\frac{i\pi}{5}}\right)^{5} = e^{i\pi} =-1 [/tex]
And so on...
Okay, I see it now. Ya, I forgot n=4. I see what you mean about only having 5 answers because when n=5 it just cycles back around to (1/5)*pi.
Thank you so much for your patience. I'm sure this was very frustrating for you.
Yes, it's just as you say; it cycles back.
Not at all.
I myself had a hard time understanding why a single "number" would have 5 roots when I was introduced to the idea.
Related Threads on Complex roots
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
