Component bias vs. Biasing
Is there not a difference between bias as in "A diode is forward/reverse biased" and establishing the terminal voltages/currents needed to bring say a transistor to the quiescent point?
Just curious
Answers and Replies
CWatters
2,298
Not really. Bias basically means offset. Just about every semiconductor needs some sort of DC offset to be applied to the input signal to get the device to work as intended.
For example diodes don't switch from conducting to non conducting at 0V there is an offset of 0.7v typically. Likewise transistors only act as linear amplifiers over part of the possible range of voltages that could be applied to them. That range isn't typically centered on 0V, there normally has to be a DC offset or bias.
Related Threads on Component bias vs. Biasing
  • Last Post
9K
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
25K
  • Last Post
  • Last Post
