What Are the Correct Components of a 20km Displacement at N30°E?
In summary, a vector is a mathematical quantity that has both magnitude and direction. It is represented by an arrow pointing in the direction of the vector, with the length of the arrow representing the magnitude. The components of a vector are the individual parts that make up the vector's magnitude and direction. The magnitude of a vector can be found using the Pythagorean theorem. A scalar is a mathematical quantity that only has magnitude and no direction, while a vector has both magnitude and direction. Vectors are typically represented using boldface letters or by adding an arrow above the letter, and the magnitude of a vector is denoted by putting vertical bars around the vector's symbol.
bobby_burke
A boat sails in a straight line 20km [N30°E]. What are the components of its displacement to the north and east?
the answers given are 17 km [N] and 10 km [E], but using the formulae
Ay = A Sin σ and Ax = A Cos σ, I've got the values mixed up... could it be because I've drawn it wrong? I've got it drawn as 30° North of East... Does N30°E mean 30° east of north?
hey Bobby,
yes, it does mean 30 degrees east of north. therefore your sigma value is 60 deg instead of 30.
that should fix you :smile:
Beau
Yes, N30°E means 30° east of north. The components of a vector are the parts that make up the vector's magnitude and direction. In this case, the magnitude is 20km and the direction is N30°E. To find the components, we can use the trigonometric formulas you mentioned: Ay = A Sin σ and Ax = A Cos σ. In this case, A represents the magnitude (20km) and σ represents the direction (30°).
To find the component to the north, we use Ay = 20km * Sin 30° = 10km [N]. This means that 10km of the boat's displacement is in the north direction.
To find the component to the east, we use Ax = 20km * Cos 30° = 17.32km [E]. This means that 17.32km of the boat's displacement is in the east direction.
It is possible that you may have drawn the vector incorrectly, which could have resulted in the mixed up values. Make sure to double check your drawing and use the correct values for the magnitude and direction when using the trigonometric formulas.
What is a vector?
A vector is a mathematical quantity that has both magnitude (size) and direction. It is represented by an arrow pointing in the direction of the vector, with the length of the arrow representing the magnitude of the vector.
What are the components of a vector?
The components of a vector are the individual parts that make up the vector's magnitude and direction. In a two-dimensional vector, the components are typically represented as the horizontal and vertical parts, often referred to as the x-component and y-component. In a three-dimensional vector, there may be three components: the x-component, y-component, and z-component.
How do you find the magnitude of a vector?
The magnitude of a vector can be found using the Pythagorean theorem. This involves taking the square root of the sum of the squares of the vector's components. In other words, for a two-dimensional vector with components x and y, the magnitude can be found using the formula √(x² + y²).
What is the difference between a scalar and a vector?
A scalar is a mathematical quantity that only has magnitude (size) and no direction. Examples of scalars include temperature, mass, and time. A vector, on the other hand, has both magnitude and direction. Examples of vectors include velocity, force, and displacement.
How are vectors represented in mathematical notation?
Vectors are typically represented using boldface letters (such as v) or by adding an arrow above the letter (such as →v). Additionally, the magnitude of a vector is often denoted by putting vertical bars around the vector's symbol (such as |v|).
