Compressed Nitrogen
Hello, first time on this site and wondered if any one could help me on what the proper equation or equations would be to answer this question.
I have a 300 cubic foot tank of nitrogen air that will provide nitrogen to a rectangular pipe at 5 psi with a flow rate of 10 CFM to atmosphere at the end of the rectangular pipe. The question is how long would it take the 300 cubic foot tank to empty?
Answers and Replies
berkeman
Mentor
60,016
10,224
Welcome to the PF. :smile:
I think we need the starting pressure in the tank as well. It is regulated down to 5psi for the flow, right?
Also, this sounds a bit like a schoolwork question, but I'm guessing it is for your work?
Yes it is for work. And also yes it will be regulated down to 5 psi for the flow. The Tank will actually hold 341 Cubic feet at 3500 psi.
Yes I am. I don't know if I am looking at this problem the right way though.
I am not sure how to get an estimate with that equation with respect to time?
berkeman
Mentor
60,016
10,224
You have an outflow rate at 5psi and an initial stored volume of gas...
okay. the initial time it would take from my calculation with a 341 cf tank at 10 cfm is 34.1 minutes. Am I correct though that the pressure drop in the regulator and the length and area of the piping change the depletion rate of the tank as well?
from what I have calculated it is 10.63 Kg in the tank with a mass flow rate out of the rectangular pipe is 3.55 Kg/m
4,725
So, from this, it seems that, if the flow rate did not decrease as the tank emptied, it would take about 3 minutes to empty the tank. Is that a good enough answer for you?
4,725
That 10.63 kg can't be right. I get about 2600 kg. I haven't checked your discharge rate yet, but maybe that's wrong too.
4,725
I get a discharge rate of 15.7 kg/m. Based on an initial mass of 2600 kg, it would give a (very rough) emptying time on the order of about 3 hours.
yes it does thank you. I thing using liquid nitrogen would be better for this use.
Oh Okay. Thank you very much for your help.
Related Threads on Compressed Nitrogen
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
