Compton effect equation
  • Thread starter asdf1
for the following question:
x-rays scattered by a crystal are assumed to undergo no change in wavelength. show that this assumption is reasonable by calculating the compton wavelength of a Na atom and comparing it with the typical x-ray wavelength of 0.1nm.
my problems:
1) why doesn't x-rays undergo any change in the first place?
2) the question doesn't give you an angle, so won't there be 2 variables in
the compton effect equation?
Answers and Replies
Astronuc
Staff Emeritus
3,453
The Compton wavelength of a particle is given by [itex]\lambda_C = h/mc[/itex] where m is the mass of the particle. The Na atom has an atomic mass of approximately 23 amu = 23*1.66x10-27 kg.
Compare that wavelength to the 0.1 nm.
X-ray scatter (as opposed to Compton scattering) is the basis of X-ray diffraction which is used to measure the distance between atoms in a crystal, i.e. lattice constant.
The problem is not asking about Compton scattering where an electron is displaced by an X-ray.
See - http://en.wikipedia.org/wiki/X-ray_crystallography
opps~
thank you very much!!! :)
hang on a second...
if that has nothing to do with the compton effect, then why's it called the compton wavelength?
The Compton wavelength is a constant in the Compton scattering equation. By calculating it you should see that the scale of the Compton effect is small compared to the original wavelength.
Related Threads on Compton effect equation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
