Find the Wavelengths of Compton Scattered Photon and Original Photon
In summary: Almost - the mc^2 is the electron's rest energy. It's not in motion initially, so it does not contribute to the initial momentum. And it does not contribute to the photon's energy after collision. So what's missing in your equation? It's a piece of the energy of the initial photon.
majinsock
Okay, so here's the problem:
In a Compton scattering experiment, a photon is scattered through an angle of 90.0 and the
electron is set into motion in a direction at an angle of 20.0 to the original direction of the
photon.
(a) Explain how this information is sucient to determine uniquely the wavelength of the
scattered photon.
(b) Find this wavelength.
λ2 - λ1 = (h/m c)(1 - Cosθ)
So, with the angle I'm given I can find Δλ, but I won't be able to find λ2 which is what I believe the question is asking me to find. I feel like I should be using the angle of the electron but I don't really see how I can. Can anyone help me out here? :S
Write the x and y component equations for momentum conservation:
For x, the photon has initial momentum h/λ1 and final momentum is a function of p, scattered electron angle ψ, scattered photon angle θ (actually a new photon!), and λ2. p is the scalar relativistic momentum of the electron after collision so the x component of momentum for the electron would be p*cosψ.
Similarly, for the y direction, you have 0 = a function of p, the same two angles, and λ2.
On top of that you also need to invoke energy conservation: initial photon energy plus electron rest energy = new photon energy plus relativistic electron energy which of course is E = √[(pc)2 + E02].
3 equations, 3 unknowns: λ1, λ2 and p.
Well, I'm screwed. Thanks, though.
Why? It's just basic momentum & energy conservation, and I think I gave you most of the relativistic stuff you need.
I have a vague idea of what I'm supposed to be doing but I'm just so horrible at this.
Ok, here's my attempt:
The initial momentum of the photon in the x direction PLUS the initial momentum of the electron in the x direction (would it be zero??) has to equal the sum of both final x direction momentums.
Sooooooooo
Ppix (Momentum photon inital x direction) = h/λ1
Peix (momentum electron initial x direction) = 0?
Ppfx = I have no idea
Pefx = p Cosψ (what is p exactly? Scalar Relativistic momentum? What does that mean?)
So Ppix + Peix = Ppfx +Pefx
And likewise with the y components, although I wouldn't have the first clue where to start with that
And energy. Hmmmmmm. So...
h f1 + electron rest energy = h f2 + √[(pc)^2 + E0^2]
Huh. What's E0? What's electron rest energy? What exactly is this "p"?! Yeah, I'm in bad shape right now :/
Check.
Sooooooooo
Ppix (Momentum photon inital x direction) = h/λ1 Right.
Peix (momentum electron initial x direction) = 0? Right!
C'mon - what is the magnitude of the new photon momentum - you got the right expression for the incoming one - but now take just the x component?
p = mv and m is the relativistic mass. Remember how m is corrected for relativistic motion? You should review this area.
So Ppix + Peix = Ppfx +Pefx Right.
Is there a y component of initial momentum for either the electron or the photon? As for the final, for the electron, it's going to be p times the sin of ψ, right? With a - sign since ψ is negative if you draw a picture of the "after" situation. And I know you know the new photon's momentum, but again taking just the y component.
? Exactly!
Yeah, you need to review. Relativisically, rest energy derives from the special theory which exchanges energy for mass, and you know the electron has mass ...
Ok, so would the new x component momentum for the photon be h/λ2 * Cosθ? Or is there something I'm missing?
And would the initial y components for the photon and electron be zero?
As for the final y components would they be:
Ppfy= h/λ2 * sinθ?
Pefy= p sinψ?
So, in total:
h/λ1 + 0 = h/λ2 * cosθ + p cosψ <------x components
0 = h/λ2 * sinθ + p sinψ ---> -p sinψ = h/λ2 * sinθ <--------y components
But that's assuming that I got the final x and y components right
And for energy:
hc/λ1 + mc^2 = hc/λ2 + √[(pc)^2 + E0^2] ?
I'm not totally sure how to get the last part. Is E0 rest energy?
I really do need to review this stuff. Can you let me know if this is right? And I apologize for saying that I was screwed. That was pretty immature of me. I just get so dang frustrated with this stuff!
majinsock said:
Ok, so would the new x component momentum for the photon be h/λ2 * Cosθ? Or is there something I'm missing? Right.
And would the initial y components for the photon and electron be zero? Right!
Ppfy= h/λ2 * sinθ? Yes!
Pefy= p sinψ? Almost. What did I say about the sign having to be negative? Do you see why? Draw a picture of the trajectories of the final photon & electron motion.
So, in total:
Fix the sign of p sinψ
And for energy:
mc^2 is not the rest energy. E0 = m0c2 is. mc^2 is the total energy = rest energy + kinetic energy. m is always the relativistic energy. Replace your mc^2 with E0 =m0c^2.
So now you see that you can solve for λ1 and λ2, right? Which is what the question seemingly asks for.
1. What is Compton scattering?
Compton scattering is a physical phenomenon in which a photon (usually an X-ray or gamma ray) collides with an electron, transferring some of its energy to the electron and causing it to scatter at a different angle and with a different wavelength.
2. What is the significance of Compton scattering?
Compton scattering is important because it provides evidence for the wave-particle duality of light, as well as helping to explain the behavior of X-rays and gamma rays in materials. It is also used in medical imaging techniques such as X-ray computed tomography.
3. How is Compton scattering different from other types of scattering?
Compton scattering is different from other types of scattering, such as Rayleigh scattering or Thomson scattering, because it involves a transfer of energy from the photon to the electron, resulting in a change in the wavelength of the scattered photon.
4. What is the Compton wavelength?
The Compton wavelength is a fundamental constant of nature that is used to describe the wavelength of a particle with a given mass. It is defined as the wavelength of a photon that has the same energy as the particle at rest.
5. How is Compton scattering related to the study of matter?
Compton scattering is related to the study of matter as it provides insight into the behavior of particles at the atomic and subatomic level. It is also used in experiments to measure the properties of particles, such as their mass and charge.
  • Atomic and Condensed Matter
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
