Computer Icon Physics
  1. Dec 4, 2006 #1
    I have a question. Are the Icons on my desktop entities that follow mathematics of "classical" physics, or are they entities that follow mathematics of "quantum physics" ? Thanks for any clarity that can be provided.
  3. Dec 4, 2006 #2
    Computer icons are objects which are described by the rules laid out by the operating system's user interface (UI).
    Assuming that you have a common UI (XP, OS X Aqua, Gnome, KDE, Java Desktop System etc.), these rules will not correspond to the rules of classical physics nor quantum physics.
  4. Dec 5, 2006 #3
    :confused: I am not interested in "rules" but mathematics. It seems to me that position and momentum of all objects of reality must either be explained by mathematics of classical physics (chair) or quantum physics (electron) or perhaps both ??. The icons on my computer desktop are objects of reality, clearly I collapse their wavefuntion when I observe them. So my question, do the icons follow the HUP as relates to their position and momentum on my desktop ? If not then clearly QM theory is not the correct mathematics to use to describe their position and momentum. Or, are you saying there is a third mathematical physics that describes the position and momentum of the icons on my desktop (neither equations of classical nor QM physics)--if so, what name is given to this third physics (or am I just very icon challenged) ?
  5. Dec 5, 2006 #4
    Danger
    I suspect that you're taking things a bit too seriously here. 'Observer dependent reality' doesn't apply on a macroscopic scale. Your icons appear as they do because that's how the CPU instructs the monitor.
  6. Dec 5, 2006 #5
    chroot
    Staff Emeritus
    Indeed, look into "decoherence." To skip to the point, everything externally visible on your computer -- the phosphors on the screen, etc. -- is not capable of being in quantum mechanical superposition, because of it the enormous number of interactions it has with molecules in the air, photons of light from your desk lamp, and so on.
    - Warren
  7. Dec 6, 2006 #6
    These icons are NOT objects of reality. They only exist in the virtual world your computer creates. In this virtual sense those icons have exact and definite positions and shapes, since this data is stored in binary in both the video memory and in some settings file.
    So when you observe an icon there is no "icon wave function" to change, only the wave functions of all the varying nick-nacks that make up the pixels on the monitor.
  8. Dec 6, 2006 #7
    vanesch
    Staff Emeritus
    I think that if anything, these icons are classical, because their state is given by a finite-state machine (which is a special form of classical dynamics).
  9. Dec 9, 2006 #8
    They are classical because "they are too big to be described by QM". I mean, they are macroscopic objects of which the behaviour is classical BY DEFINITION. If you wanna have a more formal explanation i would also go for : decoherence...
    Again, do NOT attach too much value to this classical physics/QM boundary. both formalisms work perfectly well within their regimes of validity. Though we do not know the exact distance scale where the QM world becomes classical and the other way around, such matters are NOT the fundamental questions that need to be asked. What matters is that both theories are completely in agreement with experimental data...
    marlon
  10. Dec 9, 2006 #9
    Hurkyl
    Staff Emeritus
    Just to emphasize this point some more...
    An icon is not a real object. Period. The thing you "see" is an abstract entity that your brain creates when you look at your monitor. Your computer is programmed to simulate the visual patterns that a real object might generate, via flashing tiny red, green, and blue lights at you.
    This process happens with real objects too -- an apple redirects colored photons at your eyes, and your brain creates an abstract entity corresponding to those photons. The difference is that the "abstract apple" in your brain corresponds to an actual object in reality, whereas the "abstract icon" in your brain does not.
    Another example of this is when you shine a flashlight on a wall. You see a "spot" on the wall, but there is no physical object that corresponds to that spot.
  11. Dec 9, 2006 #10
    Thank you, very clear. But can we then hold the same logic to be true for the quark--that is, that the quark is like the icon, and the spot on the wall, not a true "physical object" ?
  12. Dec 9, 2006 #11
    Thank you, but why would not a fundamental question of interest be to know the mathematics of the "exact" boundary between classical and QM theories ?
  13. Dec 9, 2006 #12
    chroot
    Staff Emeritus
    There is no "exact" boundary. Quantum mechanics becomes indistinguishable from classical mechanics in the limit of a large ensemble. The larger your ensemble is, the more accurate the agreement between the two theories.
    - Warren
  14. Dec 9, 2006 #13
    Hurkyl
    Staff Emeritus
    What logic?
    Also, why would one think a quark is analogous to an icon or a spot on the wall?
  15. Dec 10, 2006 #14
    vanesch
    Staff Emeritus
    That's the "shut up and calculate" attitude :tongue:
  16. Dec 10, 2006 #15
    Only to the extent that neither of the three are independent entities. But, anyway, it would appear the OP has been answered to some degree--the behavior of the computer icon, as I click on it and move it here and there, is not explained by mathematics of quantum theory.
  17. Dec 11, 2006 #16
    But photons are physical objects, aren't they?
    Furthermore, isn't an icon the representation of a set of transistor's states? These states, and a set of them, should be something physical (and transistors works according to QM so, maybe, icons actually obey to QM).
  18. Dec 11, 2006 #17
    Photons are physical objects, but the "spot on the wall" is something the human brain abstracts as an object, not a real physical object.
  19. Dec 12, 2006 #18
    If you mean to see something in a spot, like a face or the moon or the american flag, then I agree with you, is not a physical object, but a simple spot has position, dimensions, intensity distribution ecc. so it should be real. Or I have misinterpreted the meaning of the english term?
  20. Dec 12, 2006 #19
    Three words:
    Too much TV.
  21. Dec 12, 2006 #20
    Depends on how you define a physical object. I would claim that photons and let's say a tennis ball are defined in a very different way. The bal is an object in the classical sense : with finite spatial boundaries. A photon is an object with finite boundaries in an energy base (not in a spatial base). A photon is a chunk of energy, and do we observe those in the same way as we observe a car ???
    greets
    marlon
