Homework Help: Concave Mirror
  1. May 3, 2012 #1
    Suppose the radius of curvature of a concave mirror is 5.0 cm
    a) Find the object distance that gives an upright image with a magnification of +1.51.
    2. Relevant equations
    1/Do + 1/Di= 1/f
    m=-di/do=hi/ho
    3. The attempt at a solution
    First i convered all cm into m.
    f=R/2, so .05/2 = .025.
    1/.025=40
    then I used m=-Di/Do. Since don't know Do or Di, I substituted for the unknowns using 1/Do + 1/Di= 1/f
    I came up with...
    m=-[40-(1/Do)]/[40-1/(40-1/Do)] and solved for Do.
    I got Do=.02506m.
    Online HW says it's wrong.
    Any help is GREATLY appreciated. What I did makes sense to me but obviously there's an error or just some major concept I don't understand. Thank you so much for taking the time!
  3. May 3, 2012 #2
    collinsmark
    Okay, everything seems right so far. :approve:
    I'm not sure why you would want to invert that at this point in the process, but okay.
    Substitution is the right idea. :approve:
    Now you've lost me. :uhh:
    So far, you've already figured out
    [tex] \frac{1}{D_o} + \frac{1}{D_i} = \frac{1}{f} [/tex]
    and
    [tex] m = -\frac{D_i}{D_o}. [/tex]
    Rather than going the other way around, try substituting [itex] D_i = -mD_0 [/itex] into the first equation. Also substitute [itex] f = R/2 [/itex] into the first equation. It might make it a little easier to solve for [itex] D_o [/itex] that way. (Hint: then find a common denominator for the left side of the equation :wink:)
  4. May 3, 2012 #3
    Oh god that's SO much simpler than what I was trying to do. Thanks a million!
  5. May 4, 2012 #4
    Redbelly98
    Staff Emeritus
    Glad it worked out. By the way, I find it easier to work in cm rather than meters for this problem. For example, "1/2.5" is easier (for me) to work with than "1/0.025". In the end you get the same answer, of course.
