Concaveness and continuity
  • Thread starter hermanni
hermanni
25
Hi all,
I have the following question: Suppose f: [0, ∞) [itex] \rightarrow [/itex]ℝ and f is concave , nondecreasing and bounded on [ 0, ∞) . Does it follow that f is continuous on [ 0, ∞) ? Thanks in advance, H.
Answers and Replies
tiny-tim
25,838
255
hi hermanni! :wink:
tell us what you think, and then we'll comment! :smile:
(start by writing out the definition of "concave")
DonAntonio
606
Hi all,
A step function is non-decreasing, convex (or concave) and we can make it bounded, but won't be continuous. For example
[tex]f(x)=0\,\,,\,if\,\, x\in [0,1)\,,\,f(x)=1\,\,,\,if\,\, x\geq 1\,[/tex]
DonAntonio
micromass
Staff Emeritus
Insights Author
22,178
3,305
How is a step function convex??
DonAntonio
606
Very simple: it fulfills the definition of concave upwards (if the steps go up) or concave downwards (steps down), just as a constant
function does as well.
DonAntonio
micromass
Staff Emeritus
Insights Author
22,178
3,305
DonAntonio
I don't see how. Take the function
[tex]f:]-1,1[\rightarrow \mathbb{R}:x\rightarrow \left\{\begin{array}{l} 0~\text{if}~x\leq 0\\ 1 ~\text{if}~x>0 \end{array}\right.[/tex]
This is the function you mean right??
According to the definition, this function is convex if for all [itex]x,y\in ]-1,1[[/itex] and [itex]t\in [0,1][/itex] holds that
[tex]f(tx+(1-t)y)\leq tf(x)+(1-t)f(y)[/tex]
But take x=-1/2, y=1/2 and t=1/4, then
[tex]f(tx+(1-t)y)=1[/tex]
while
[tex]tf(x)+(1-t)f(y)=3/4[/tex]
and this does not satisfy the inequality.
Furthermore, it violates the following theorem: http://planetmath.org/ContinuityOfConvexFunctions.html [Broken]
DonAntonio
606
No, my function's defined on the convex non-negative ray [itex]\,[0,\infty)\,[/itex]
while
Point taken, but eventhough my example indeed doesn't quite fit in the traditional definition, I will change it slightly and still
will we get a counterexample:
[tex]f(0)=0\,,\,f(x)=1\,\,,\,\forall\,x>0[/tex]
The above function is convex upwards in [itex]\,[0,\infty)\,[/itex] but not continuous there.
DonAntonio
micromass
Staff Emeritus
Insights Author
22,178
3,305
OK, but I think the OP cares more about convex downwards...
DonAntonio
606
No problem: interchange zero and one in my last message's definition.
DonAntonio
micromass
Staff Emeritus
Insights Author
22,178
3,305
That's not nondecreasing :frown:
pwsnafu
85
Hint: suppose you already have a function that is continuous, non-decreasing, concave and bounded on the open interval ##(0,\infty)##. Then continuity on ##[0,\infty)## is completely determined by ##f(0)##.
haruspex
Insights Author
7,958
There is perhaps some confusion about the terms convex and concave. I believe that the standard definition is such that for twice differentiable functions convex would mean the second derivative is never negative. I.e. convexity/concavity is as viewed from 'below'.
This would make DonAntonio's counterexample at post #7 valid. But I suspect the OP was using the terms inversely, so suppose 'convex' was intended. As micromass/pwsnafu point out, the continuity is assured everywhere except at 0 by the convexity alone. The only question is whether the non-decreasing condition makes it continuous at 0+. I believe it does by a simple variation on the proof at the PlanetMath site quoted.
Suggested for: Concaveness and continuity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
