Homework Help: Concept MC Questions
  1. Dec 7, 2005 #1
    Hi, I have some review multiple choice questions, and some of them, I cant understand why the answer is so. If you could clarify the concepts, that'd be great!
    Which statement best describes the Earth’s rotation about its
    axis?
    a)The tangential velocity is the same at all points on the Earth’s
    surface.
    b)The angular velocity is greatest at the Earth’s equator.
    c)The angular acceleration is zero at all points on the Earth’s
    surface.
    d)The centripetal acceleration of a point on the Earth’s surface
    is zero.
    The answer is C. For this one, I didnt even know where to begin. I only could eliminate D because since it is rotating, it has to have a centripetal acceleration.
    A ladder leans against a frictionless wall, but is prevented from
    falling because of friction between it and the ground. If you
    shift the base of the ladder toward the wall,
    a) The normal force on the ladder from the ground decreases.
    b) The static frictional force on the ladder from the ground
    decreases.
    c) The normal force on the ladder from the wall increases.
    d) The maximum static frictional force on the ladder from the
    ground increases.
    e) None of the above.
    The answer is B. I thought the answer was E because the normal force is the same, and the cofficient of static friction is the same, then the force of static friction should be the same.
    Two astronauts (both 70 kg) are floating motionless in empty
    space far from the Earth. One of them is holding a 20-kg
    oxygen tank. He pushes the tank directly toward the second
    astronaut, who catches and holds it. If the speed of the tank
    relative to the second astronaut was 2.0 m/sec, then the final
    speed of the second astronaut relative to the first one (after the
    second one has caught the tank) is:
    (A) 0.4 m/sec
    (B) 0.6 m/s
    (C) 1.0 m/s
    (D) 1.5 m/s
    Answer is C. Im really not too sure where to being here
    Thanks in advance
  3. Dec 8, 2005 #2
    Chi Meson
    First question: look up the definition of angular acceleration. read it aloud. Think to yourself, which part of the earth completes one rotation in a shorter time than other parts of the earth?
