Concept of limit
  • Thread starter vktsn0303
How can it be proved that as lim n tends to infinity, (n2-1)/(n2 + n + 1) tends to 1 ?
Answers and Replies
SteamKing
Staff Emeritus
12,798
1,670
Have you tried L'Hopital's Rule?
jbunniii
Insights Author
257
Divide the numerator and denominator by ##n^2## to obtain
$$\lim_{n \to\infty} \frac{1 - 1/n^2}{1 + 1/n + 1/n^2}$$
The numerator and denominator both have limit ##1## as ##n \to\infty##, therefore so does the quotient.
Likes fian and Emmanuel_Euler
Well, I actually had a fundamental doubt (silly even) for which reason I had posted the question mainly. I am a newbie to the concept of limits. My doubt is as follows. Why should we look to modify the numerator or the denominator or both? Why not just consider that as n tends to infinity the division in question gives us (infinity)/(infinity) which is not defined. This would lead us to the conclusion that the problem is therefore not solvable. Why can't this just be the case. I have actually observed many problems being solved by modifying the numerator and denominator. But it just seems so obvious that (infinity)/(infinity) is the actual result.
you are right.
you can try L'Hopital's Rule. but you must do it twice.
jbriggs444
10,527
5,120
Because that would be assuming that the limit of the quotient is the quotient of the limits. That principle is almost true. It holds when all three limits exist (and when the limit of the denominator is non-zero). But when the limit of the numerator and denominator both fail to exist, one is left with no prediction for the limit of the quotient. It is an "indeterminate form".
7,519
You're not really modifying either the numerator or denominator. All that's happening is the factoring of both num. and denom.
$$\lim_{n \to \infty}\frac{n^2 - 1}{n^2 + n + 1} = \lim_{n \to \infty}\frac{n^2(1 - 1/n^2)}{n^2(1 + 1/n + 1/n^2)} = \lim_{n \to \infty}\frac{n^2}{n^2} \lim_{n \to \infty}\frac{1 - 1/n^2}{1 + 1/n + 1/n^2}$$
It's legitimate to split a limit of a product into the product of the limits, if the separate limits exist. The first limit all the way to the right exists and is 1. As already stated, the second limit on the right also exists, and also is 1, so the limit on the left exists and is 1.
jbunniii
Insights Author
257
Consider a very simple example. Let us define a constant sequence: ##x_n = 1## for all positive integers ##n##. Clearly this sequence has limit ##1##. Now let's rewrite the same sequence another way. Most likely you agree that ##n/n = 1## for every ##n##, so I can write ##x_n = n/n##. I have not changed the value of the sequence for any ##n##, so its limit cannot change: it is still ##1##. It doesn't become ##\infty/\infty## just because the numerator and denominator both approach infinity.
The key observation is that
$$\lim_{n \to \infty} \frac{a_n}{b_n}$$
is not generally the same as
$$\frac{\lim_{n \to\infty}a_n}{\lim_{n \to \infty} b_n}$$
unless both ##\lim_{n \to\infty}a_n## and ##\lim_{n \to \infty} b_n## exist (and the latter is nonzero).
Returning to the original problem, the numerator and denominator of
$$\frac{n^2 - 1}{n^2 + n + 1}$$
both approach infinity as ##n \to \infty##, so we cannot conclude anything without doing some more work. The point of modifying the fraction, by dividing the numerator and denominator by ##n^2##, is that we end up with
$$\frac{1 - n^2}{1 + 1/n + 1/n^2}$$
In this form, the numerator and denominator approach finite limits (##1## in both cases), so now we can apply
$$\lim_{n\to\infty}\frac{a_n}{b_n} = \frac{\lim_{n \to\infty}a_n}{\lim_{n \to \infty} b_n}$$
where ##a_n = 1 - n^2## and ##b_n = 1 + 1/n + 1/n^2##.
Likes vktsn0303
PeroK
Insights Author
2021 Award
20,119
11,464
Another approach. Define:
##f(n) =\frac{n^2 - 1}{n^2 + n + 1}##
Does ##f(n)##, as n increases, eventually get close to 1 and stay there? Whatever definition of "close" you choose?
If you say "close" is within 0.001, then eventually it gets close (and stays close).
If you say "close" is within 0.000001, then eventually it gets close (and stays close).
No matter how you define "close", f(n) eventually gets that close to 1 and stays close.
So, you might want to say that
As n increases, f(n) gets arbitrarily close to 1.
Or, in shorthand:
##\lim_{n \to \infty} f(n) = 1##
Note that there is no concept here of "plugging in" ##n = \infty##. That is meaningless.
Related Threads on Concept of limit
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
