Conceptual mechanics problems
In summary, the conversation discusses two problems related to Newton's laws of motion. The first problem involves a boat, fan, and sail, and the correct application of Newton's second and third laws to determine if the boat will move. The second problem involves a bird flying in a closed or open container, and the effect on the container's weight. The conversation also includes a discussion on the correct reasoning for both problems.
Vibhor
971
40
First problem -
[/B]
F=Ma
Thinking in terms of Newton's second law ,since there is no external force on the system(fan+sail+boat) ,the boat should not move .
Thinking in terms of Newton's third law ,the fan pushes on the air with some force F (say to the right) .The air pushes on the fan(and boat) to the left with same force F (to the left ). The air pushes on the sail(and boat) to the right with force F . So net force on the boat is zero . Hence the boat should not move .
Is this reasoning correct ?
Many Thanks
Yes.
Thanks :smile:
Second problem : If a bird sitting in a closed airtight container starts to fly what happens to the weight of the container (the container is placed on a weight balance).What would happen if it was a cage (i.e air could escape out) ?
In closed container :
1) If the bird hovers (flies at the same place) ,then the weight registered would be same . The force of gravity on the bird Mg would be balanced by the upward force of air F i.e F=Mg .The air would be pushed down by the same force F . Doing a force balance on the mass of air ,this downward force on air would be balanced by an upward normal reaction force from the container . The weight registered would again be same .
2) But if the bird accelerates upwards ,then the force exerted by the air would be more than its weight Mg . This results in an increased force on the bottom of the container . Hence the weight increases during the period the bird accelerates upwards .
3) If the bird accelerates downwards ,then the force exerted by the air would be less than its weight Mg . This results in decreased force on the bottom of the container . Hence the weight decreases during the period the bird accelerates downwards .
In open cage :
If the bird hovers at the same place , then some of the air escapes out of the cage and the weight registered would be less as compared to when the bird was sitting at the bottom .
Vibhor said:
.[/B]
First problem -
F=Ma
Many Thanks
No, it is incorrect. The boat is not an isolated system and the air molecules "rebound" against the sail (if the molecules would "stick" to the sail, then you would be correct). The molecules push on the right with a force larger than F when the hit the sail because they rebound with a nonzero velocity (if they had a zero velocity after the bounce, then you would be right). There are many classroom demonstrations showing that the boat actually moves forward. The simplest way to see that the boat will actually move forward is to use conservation of momentum. Before turning the fan on, the total momentum is zero. At the end, there is a flow of air backward (going away from the sail), after having rebounded against the sail. So there must be a net momentum of the boat in the direction of the sail, i.e. forward. The boat will move forward. You can also do it in two steps (being pushed by the fan and then rebounding against the sail), considering one air molecule at a time, say. You will find that the boat ends up having a net momentum forward.
Likes Vibhor
Vibhor said:
3) If the bird accelerates upwards downwards
Yes.
Vibhor said:
In open cage :
Depends; toroidal circulation comes into play, as it does in the first case.
Thanks for replying.
In the first step ,the boat has a backwards(towards left) momentum and the air has a forward momentum (towards right). In the second step , after the air rebounds ,the boat would have a forward momentum . The result is that even though the boat moves a little forward and backward ,the net effect is that it stays at the same place .
What do you think ?
Bystander said:
Yes.
Are reasoning for 1) and 2) correct i.e when the bird hovers at the same place and when it accelerates upwards in the closed container ?
Yes.
Bystander said:
Yes.
Ok . So , we have definite answers when the container is closed . But if the cage is opened , then weight might increase or decrease .
Is that correct ?
In the first step ,the boat has a backwards(towards left) momentum and the air has a forward momentum . In the second step , after the air rebounds ,the boat would have a forward momentum . The result is that even though the boat moves a little forward and backward ,the net effect is that it stays at the same place .
What do you think ?
Close. But my point is that the overall effect is that the boat *will* move forward. As I said, it is easier to do in terms of momentum (but we can also do it in terms of forces).
Let's call p1 the momentum of one air molecule after it is "ejected" by the fan. At that point, th molecule has a momentum p1 to the right and the boat has a momentum p1 to the left.
Now the molecule rebounds on the sail. Let's consider an elastic collision, first. Then the molecule goes from having a momentum p1 to the right to having a momentum p1 to the left, therefore its momentum has *changed* by 2 p1 to the left during the "collision". Therefore the boat has seen its momentum to the right increase by 2p1 during that collision.
So overall, the total change of momentum of the boat is -p1+2p1 = +p1 to the right. So the boat moves forward. This is confirmed by doing the actual experiment.
Of course, we can simply say that at the very beginning (before the fan is on), the air molecule has no momentum and at the end, it has a momentum p1 to the left so the boat has a momentum p1 to the right.
In real life, the collision with the sail is not elastic but the air molecules still have a nonzero momentum to the left after rebounding.
Now, in principle someone could argue: what prevents from the molecule to end up having a zero momentum at the very end? This is not enforced by conservation of momentum but I think that conservation of energy is sufficient to make the case that the energy provided by the fan must translate into overall nonzero motion of th boat and the air molecules at the end (assuming a few reasonable things)
Likes Vibhor
Nice reasoning :smile:
I did not understand your point here . Could you explain a little more ?
How is momentum approach and Newton's II and III laws giving different answers ? Although the momentum approach makes sense , yet what is the flaw in the OP ?
Vibhor said:
First problem -
[/B]
F=Ma
The system is not closed. The surrounding air, brought into motion, exerts force on the boat system.
OK.
And what is the flaw in applying Newton's 3rd law as done in the OP.
I find this bouncing air argument rather dubious. Any bouncing air molecules would find themselves tangled up in the stream of air from the fan. The air would end up exiting sideways.
It might work if you had the sail in a curve and directed the air only onto one half of it; the air could follow around the curve and return from the other half. Of course, the sailor would do better just to point the fan out the back of the boat in the first place.
Only that it assumes the air, having hit the sail, becomes stationary again (and that's relative to the surrounding air, not relative to the boat).
It might be easier to think in terms of picking up balls floating near the boat and hurling them at the sail. If they continue to move with the boat, the boat slows down (if it was moving before); if they bounce back just enough that they are stationary relative to the water, no change to the boat's speed; if they bounce back any harder (landing in the water) you go forwards.
1. What is conceptual mechanics?
Conceptual mechanics is a branch of physics that deals with the study of motion and the forces that govern it. It focuses on understanding the fundamental concepts and principles behind mechanical systems, rather than solving numerical problems.
2. What types of problems are typically included in conceptual mechanics?
Conceptual mechanics problems often involve scenarios where objects are in motion or at rest, and the forces acting on them are described. They may also require understanding of concepts such as inertia, Newton's laws of motion, and energy conservation.
3. How do I approach solving a conceptual mechanics problem?
To solve a conceptual mechanics problem, it is important to first identify the given information and the unknown variables. Then, use the fundamental principles and equations of mechanics to analyze the situation and determine the relationships between the variables. Finally, apply logical reasoning and critical thinking to arrive at a solution.
4. How can I improve my understanding of conceptual mechanics?
To improve your understanding of conceptual mechanics, it is important to practice solving various types of problems, read textbooks and other resources on the subject, and seek guidance from a knowledgeable instructor or tutor. Additionally, having a strong foundation in calculus and algebra can greatly aid in understanding the concepts and principles of mechanics.
5. Are there any real-world applications of conceptual mechanics?
Yes, conceptual mechanics is essential in understanding and predicting the behavior of physical systems in many real-world applications, such as designing structures and machines, analyzing the motion of celestial bodies, and developing technologies like rockets and satellites. It also serves as the foundation for other branches of physics, such as thermodynamics and electromagnetism.
  • Classical Physics
