Is My Calculation of Force on a Gas-Filled Box Correct?
In summary, the conversation discusses a problem regarding the theory of gases. The question involves finding the net force acting on each face of a cube-shaped box containing air at a constant volume and varying temperatures. The equations and steps used to find the final pressure and force on each face are also described. After some clarification, it is concluded that the net force on each face is zero before and after the temperature change, as the gas and atmospheric pressure balances out. However, when the temperature is raised, the net force becomes 1.347 kN due to the increase in pressure.
pc2-brazil
205
Good morning,
(This is not homework; just curiosity)
I found a little problem concerning Theory of Gases. I was able to solve it, but I want confirmation about if this is correct or not.
Suppose I have a cube-shaped box, with edges measuring 20 cm = 0,2 m, which contains air, with pressure of 1 atm = 101325 Pa, in the temperature of 300 K. Suppose the volume of the box remains constant, and, then, I raise the temperature up to 400 K.
I want to find the net force acting upon each face of the box.
As the volume of the box remains constant, I will use the equation P1/T1 = P2/T2, in which P and T are, respectively, pressure and temperature.
Other equation: P = F/A (force = pressure/area), with force in Newtons, pressure in Pascals and area in m².
Firstly, I will find the pressure (in Pascals) inside the box at 400 K using the first equation above:
[tex]\frac{P_{1}}{T_{1}}=\frac{P_{2}}{T_{2}}[/tex]
initial pressure is 101325 Pa, initial temperature is 300 K and final temperature is 400 K.
[tex]\frac{101325}{300}=\frac{P_{2}}{400}[/tex]
therefore, the final pressure P2 = 135100 Pa.
Now, I will find the force acting upon each face. The area of each face is the square of the edge:
A = 0,22
A = 0,04 m²
P = F/A
F = PA
F = 135100.0,04
F = 5404 N = 5.4 kN
Is this correct?
Thank you in advance.
Not exactly. The question asks for the NET force. What other force (pressure) is acting on the sides of the boxes?
AM
AM
I was forgetting the fact that the side of the box never moves because of the force exerted by the gas. Then, 5,4 kN is the force exerted by the gas, not the net force.
If the side of the box remains at rest, then its net force should be zero, because the side is pushed by the force exerted by the gas, but this force is balanced by the friction exerted on it by the adjacent sides: the roof, the floor and the other two sides. Is this right?
That balances the net force but that is not the force you have found. Put it this way: Is there a net force on the box sides when you begin? If the sides were made out of light cardboard taped with scotch tape, would it explode just sitting there? Using your calculation, it would (it would have about 4 kN of force on each side.)
AM
AM
I think that I'm not understanding correctly what you are saying. When I begin (before the temperature change), the net force on a side of the box is zero. After the temperature change, it is also zero, isn't it? It means that the sum of all contact forces of this side of the box with the adjacent sides balances the 5.4 kN exerted by the gas. Thus, before the temperature change, the sum of these contact forces was 101325 Pa * 0,04 m² = 4053 N.
It is sitting in air with pressure 1 atm and temperature 300k - at least that is what appears from the question. It does not say it is sitting in a vacuum. The box has zero net outward force on each side to begin and puts no outward strain on the box structure. Why is that? When the temperature of the air in the box is heated there is a net outward force. This force has to be balanced by the box structure, but that is not what the question is asking. It is asking what that net (outward) force is.
AM
I think I got you now.
Inside the box, at 300 K, the pressure 1 atm of the gas equals the atmospheric pressure (1 atm), so, the force exerted by the gas (4.053 kN) and by the atmosphere (4.053 kN) on the side of the box balance each other. The net outward force is, then, zero. Is this right?
At 400 K, the pressure inside the box is 1.3 atm, which is bigger than the atmospheric pressure; the force exerted is bigger (5.4 kN) than the force exerted by the atmosphere (which continues 4.053 kN). The net outward force is, then, 5.4 - 4.053 = 1.347 kN. Is this right?
At 400 K, the pressure inside the box is 1.3 atm, which is bigger than the atmospheric pressure; the force exerted is bigger (5.4 kN) than the force exerted by the atmosphere (which continues 4.053 kN). The net outward force is, then, 5.4 - 4.053 = 0.87 kN. Is this right?
Apart from your subtraction, yes. 5.4-4.05 = 1.35 kN
OK, thank you.
I corrected the subtraction; I was in a hurry, so I mistyped it and didn't check (I did 5.4 - 4.53; I skipped the zero).
In this case, it seems that the question is ambiguous, because, for me, the net force is the sum of all forces acting in a body. In this case, I could simply say zero.
pc2-brazil said:
OK, thank you.
The question would be pointless, if that was what it was asking. In the real world it is important to know what the net outward force is on the container - for example, in order to design a container with sufficient strength to sustain that force.
AM
AM
OK. It is very interesting.
This forum is very good for someone trying to self-teach. The book I have doesn't have the answer key to this question.
1. What is the theory of gases?
The theory of gases is a branch of physics that explains the behavior of gases in terms of their microscopic particles. It describes how gases interact with each other and with their surroundings at different temperatures, pressures, and volumes.
2. What are the fundamental assumptions of the theory of gases?
The theory of gases is based on three fundamental assumptions: 1) gases are composed of particles that are in constant, random motion; 2) these particles are separated by large distances compared to their size; and 3) the particles do not interact with each other except during collisions.
3. How does the theory of gases explain the properties of gases?
The theory of gases explains the properties of gases by relating them to the behavior of their constituent particles. For example, the observation that gases expand to fill their containers can be explained by the constant motion of the particles and their ability to move freely in all directions.
4. What is the ideal gas law and how is it derived?
The ideal gas law is a mathematical relationship between the pressure, volume, temperature, and number of moles of a gas. It is derived from the combination of the three fundamental gas laws: Boyle's law, Charles's law, and Avogadro's law.
5. How does the theory of gases apply to real-world situations?
The theory of gases has many practical applications, such as in the design and operation of gas-powered engines, refrigeration systems, and weather prediction. It also helps us understand the behavior of air and other gases in our daily lives, from the inflation of a balloon to the combustion of fuel in a car engine.
