Conditional Expectation
  • Thread starter redflame34
If I have x1,x2 iid normal with N(0,1)
and I want to find E(x1*x2 | x1 + x2 = x)
Can I simply say: x1 = x - x2 and thus
E(x1*x2 | x1 + x2 = x) =
E[ (x - x2)*x2) = E[ (x * x2) - ((x2)^2) ] <=>
x*E[x2] - E[x2^2] =
0 - 1 =
-1?
Answers and Replies
mathman
450
No.
You need to transform the problem to one where x1 + x2 is a random variable.
Let u=(x1 + x2)/√2, v=(x1-x2)/√2. (I am using √2 so that u and v will be iid N(0,1))
Then x1=(u+v)/√2 and x2=(u-v)/√2
Your original problem is now E((u2 - v2)/2 |u=x/√2)
Since u and v are independent, the result is x2/4 -1/2.
I'm confused. Can you please explain more why the first solution (-1) is wrong?
[tex]X_1[/tex] and [tex]X_2[/tex] are 2 RVs, and we're told that [tex]X_1+X_2=y[/tex].
1) I understand that sum of two RVs will be a RV, but here, when we are told the sum is [tex]y[/tex], it is something like a constant? (a realization of [tex]Y[/tex] that is [tex]Y=y[/tex] I mean.)
2) if I'm right about (1), then when we are told the sum is [tex]y[/tex], it means we can focus only on one RV (accurately, I mean we can think we have two RVs: [tex]y-X_1[/tex] and [tex]X_1[/tex]). Now the solution as redflame said will be:
[tex]\int_{x_1} (y-x_1)(x_1) p(x_1) \ud x_1 = \ldots = -1[/tex]
(I'm not sure if the TeX code above is shown correctly, it is (\int_{x_1} (y-x_1)(x_1) p(x_1) \ud x_1 = \ldots = -1), (the dx_1 is not shown correctly for me).
Thanks in advance. (;
mathman
450
The argument against this approach is complicated, but a simple illustration will show that it is wrong.
Let x1 be N(0,a) and x2 be N(0,b), where a and b are different. Then we have the following:
E(x1*x2|x1+x2=x)=E(x*x2)-E(x2^2)=-b
E(x1*x2|x1+x2=x)=E(x1*x)-E(x1*2)=-a
This is obviously incorrect!
Thanks.
I'm really confused!
Can you please suggest a solution through the definition of E{x1*x2|x1+x2=x}?
I want to correct my beliefs about this kind of problems (working with sum of RVs and ...).
I think E{x1*x2|x1+x2=x}=double integral on x1 and x2 { x1 * x2 * p(x1,x2|x1+x2=x) *dx1 *dx2}
(BTW, is it true?)
Can you continue it?
and please tell me if you know a good reference for understanding these subjects. I am trying to fix my probability/statistics background knowledge in order to understand stochastic processes and estimation theory deeply.
mathman
450
The basic problem in your original approach is that by using x2=x-x1, you were redefining x2. This new x2 is N(x,1) not N(0,1) and is no longer independent of x1.
As for texts I haven't been keeping up (I'm retired). I hope someone else can help.
mathman
450
I finally understand the underlying problem with your original approach. x1 and x2 are N(0,1) when there is no condition. However their distributions change when you impose the condition x1 + x2=x.
I can give you a very simple example to show what happens. Toss a fair coin twice, and for this analysis, let heads be called +1 and tails -1. Then each toss has mean 0 and variance 1.
Now impose the condition the sum of the tosses = 2. The resulting conditional distribution for both tosses is now +1, so the conditional means are now 1 and the conditional variances are 0.
Related Threads on Conditional Expectation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
