1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Cone Related Rates Problem
  1. Nov 6, 2013 #1
    Grit, which is spread on roads in winter, is stored in mounds which are the shape of a cone. As grit is added to the top of a mound at 2 cubic meters per minute, the angle between the slant side of the cone and the vertical remains 45º. How fast is the height of the mound increasing when it is half a meter high?
    2. Relevant equations
    3. The attempt at a solution
    So I need to solve for dh/dt. I know dV/dt=2 and I know the height, but not the radius. So I draw a right triangle. Since the angle is 45º, r=h. So r=0.5. Now time to take d/dt of each side.
    I treated r as a constant and h as a function of time here. I applied the product rule and the chain rule.
    Substitue 0.5 for r and I get
    The correct answer is 8/π. Where did I go wrong?
  3. Nov 6, 2013 #2
    Staff Emeritus
    You can't treat r as a constant. As grit is added to the cone, both h and r are changing w.r.t. time.
    If r stays constant and h increases, then the angle of repose of the grit (45 degrees) will increase, which it cannot do. The angle stays constant.
  4. Nov 6, 2013 #3
    Here's the derivative I get now:
    2=1/3πr2*dh/dt + 2/3πrh*dr/dt
    This is great and all, but what am I supposed to sub in for dr/dt to solve the equation? I have two unknowns now.
  5. Nov 6, 2013 #4
    Hi Burjam! :smile:
    No, you have only one unknown (h).
    r is not an indpendent unknown, it is a function of h.
  6. Nov 6, 2013 #5
    Staff Emeritus
    You know the angle of repose of the grit (45 degrees). For each cm the height increases, how many cm does the radius increase? (Hint: draw a diagram.)
  7. Nov 6, 2013 #6
    The radius will increase at the same rate as the height because the angle is 45º and constant. I actually drew a diagram initially to get r so this is partially from that. So dr/dt=dh/dt. From here I can solve it:
    2=1/3πr2*dh/dt + 2/3πrh*dh/dt
    2=dh/dt(1/3πr2 + 2/3πrh)
    dh/dt=9/(πr2 + πrh)
    When I plug in 0.5 for r and h I get:
    Still not the right answer. What's wrong?
  8. Nov 6, 2013 #7
    It seems to me that there's an algebra issue going between the two bolded lines. I found that using ##r = h## made it fairly simple, personally.
Have something to add?
Draft saved Draft deleted
