Conform/help with calc solution
  1. Nov 29, 2007 #1
    Newton’s law of gravitation states that the force between two masses m1
    and m2 at a distance r apart is F = Gm1m2/r2 .
    (a) Find the magnitude of the gravitational force exerted by a solid hemisphere
    of radius a and constant density  on a point mass located at
    the center of the base of the hemisphere.
    (b) A particle of mass m is placed at the center of one base of a circular
    cylindrical shell of inner radius r1, outer radius r2, height h, and
    constant density . Find the force of gravitational attraction exerted
    by the cylinder on the particle.
    3. The attempt at a solution
    because the only force which would act on the bottom center of the hemisphere is pointed straight down. the force would be represented in a negative direction (-x/||x||). therefore f(x)=-mMGx/||x3||. ||x||=sqrt(x2+y2+z2).
    because the force is coming only from the z direction F(x,y,z)=-mMGz/((z2)to the 3/2power)
    is there someone to conform that.
    and please lead me to the b part
    thanks
Draft saved Draft deleted
Similar Discussions: Conform/help with calc solution
  1. Calc Help! (Replies: 12)
  2. Calc help! (Replies: 1)
  3. Calc Help please. (Replies: 1)
  4. AP Calc help (Replies: 9)
Loading...
