How Do You Multiply Multiple Percentages Correctly?
  • Thread starter chriscarson
  • Tags
    Confused
In summary, a summary of the conversation is that 78.8% of the time, multiplying fractions will result in a rounded number.
chriscarson
197
multiplication of percentage
x
94% * 91% * 91% = 78.8%
how does this becomes like that?, I m havig the result of 778414
The % sign can essentially be interpreted as ##\times 0.01##, i.e. ##36 \% \equiv 36 \times 0.01 = 0.36##
Likes chriscarson and PeroK
chriscarson said:
Homework Statement:: multiplication of percentage
Relevant Equations:: x
Can you multiply$$\frac{94}{100} \times \frac{91}{100} \times \frac{91}{100}$$What do you get?
Likes chriscarson
no , maybe that s why
If you google for "multiplication of fractions", you get links such as this.
What part is causing you difficulty?
so 0.94 x 0.91 x 0.91 = 0.778414 ?
Yes. Now express that result as a percentage.
Likes chriscarson
well just don t know what to do but it seem with the example to make them 0.91 etc you can multiply then divide by 100
just divide by 100 ? because it becomes 77.8414 not 78.8%
Apparently you just multiplied 94 x 91 x 91.
If 78.8% is the answer in your book, it looks like they rounded the result to the nearest tenth of a percent.
BTW, I moved this thread from Intro Physics to Precalc Math -- the question really has little to do with physics.
Likes chriscarson
It looks like they rounded it and then goofed with an off-by-one in the second digit. Or a similar brain-o.
Likes chriscarson
I missed that change. I think you're right, though.
Likes chriscarson
ok
chriscarson said:
but this does not effect to multiplicate the percentages right ?
No. It was a sidebar.
50x50 = 2500
50% x 50% = 25%
BTW, a mnemonic that often helped me intuitively understand operations like this is that you can think of the "multiplication" operator to mean "of" - as in "a certain amount of pie".
So:
50% x 50%
is the same as
50% of 50%
is the same as
a half of a half.
which is, intuitively, 1/4 - or 25%.
Likes Lnewqban, pinball1970 and chriscarson
50x50 = 2500
50% x 50% = 25%
So:
50% x 50%
is the same as
50% of 50%
is the same as
a half of a half.
good , seems good to remember , have to see when it s a multiplication of 10 numbers.
It's just a mnemonic - a memory aid. You don't have to use it to do the calculation - just keep it in mind so you know how the numbers should be behaving,
Likes chriscarson
oh I see ,ok
BTW, it doesn't just work with fractions and percentages. It works with whole numbers too.
eg. : two cartons of a dozen eggs gives you ... how many eggs?
Likes chriscarson and Nik_2213
Now that I remember in class,we did ...
88.2% x 94.7% x 86% = 71.8%
and it was with a scientific calculator, anybody knows what we pressed for it so maybe I remember?
You mean something like:
Likes chriscarson
D
Yes that is what the percentage sign means, per is 'divided by' and cent is a 100.
The sign tells you too, it's jumbled up dividing line with 2 noughts.
Likes chriscarson
pinball1970 said:
D
I discovered that I had to make 0.71831844 x 100 to get 71.8
pinball1970 said:
D
88.2% x 94.7% x 86% written in calculator becomes like this
had to make times not division
Yes they are expressed as decimals. One whole is 100 per cent or 100 out of 100 = 1.0
71.831844 as a % is that amount out of 100, 71.8314833/100 which is = 0.71834.
If you get stuck remember what you are doing going from fractions to % to decimals and back.
Use the easiest eg so you know. One half
Likes chriscarson
yes it s forth and back from what you are saying just times or division
View attachment 259237 had to make times not division
If you have a decimal fraction and you want a percentage: Multiply by 100.
Example: 0.5 x 100 = 50%
If you have a percentage and you want a decimal fraction: Divide by 100.
Example: 50% / 100 = 0.5
Likes Lnewqban and chriscarson
Yes @DaveC426913 gave the pie as an example and that is easiest to visualise and I would use that for fractions then play with numbers going from fractions to % and back.
yes that s what I wanted but didin t know it will work when you multiply a multiple of percentage values .
What is the process for multiplying percentages?
The process for multiplying percentages is to convert the percentages into decimals, then multiply the decimals together, and finally convert the resulting decimal back into a percentage.
Can percentages be multiplied directly?
No, percentages cannot be multiplied directly. They must be converted into decimals first before multiplying.
What is the difference between multiplying percentages and adding percentages?
Multiplying percentages involves finding the percentage of a number, while adding percentages involves finding the total percentage increase or decrease of a number.
What is the purpose of multiplying percentages?
Multiplying percentages is used to calculate the percentage of a number or to find the total percentage of two or more percentages combined.
How do I solve a word problem involving multiplying percentages?
To solve a word problem involving multiplying percentages, first identify the given percentages and determine the operation needed (finding the percentage of a number or finding the total percentage). Then follow the process of converting to decimals, multiplying, and converting back to a percentage.
  • Materials and Chemical Engineering
  • Mechanical Engineering
16K
  • Linear and Abstract Algebra
