Confused which formula to use
anthonyk2013
125
I have a question I'm having trouble with.
A wire is stretched 1.2 mm by a force of 240n. Calculate the force needed to stretch the wire 2.0mm assuming the elastic limit is not exceeded.
I'm new to physics and I have only used formulas for finding stress, strain and youngs modulas. Should I be able to find the value using one of those formulas?
Answers and Replies
arildno
Dearly Missed
10,025
135
Use the fundamental tenet of Hooke's law (for which the limit of elasticity is not exceeded), that the force must be proportional to the stretching of the wire.
The simplest use of this is that the ratio between the two forces must equal the ratio of the two stretchings.
anthonyk2013
125
I use f=-KX?
arildno
Dearly Missed
10,025
135
That is indeed Hooke's law!
Since you are not bothering about the directions of accelerations here, you can disregard the minus sign, and say that the magnitude of the force "f" equals "k" times the magnitude of the stretching X.
That is:
F=kX.
Now, you know both the force in the first instance, and the stretching in that instance.
Can you solve for "k", so that you can use that in order to find the magnitude of the force in the second instance?
anthonyk2013
125
240=K.1.2
K=240x1.2=288N ?
arildno
Dearly Missed
10,025
135
If you have the equation:
240=K*1.2
How do you solve for K?
Remember that we can switch about the order of factors in a product, and also what we term the LHS and RHS of an equation.
Thus, the above equation can also be written as:
1.2*K=240
Also, do NOT use as multiplication sign "." when you also use "." as decimal point sign!
anthonyk2013
125
240=K*1.2
1.2*K=240
Ok won't do that again.
So K=240*1.2=288N
arildno
Dearly Missed
10,025
135
Really?
How do you solve the equation:
2*x=4?
anthonyk2013
125
Sorry my bad, need to get my head in the game here.
K=240/1.2=200.
arildno
Dearly Missed
10,025
135
Now we are in agreement! :smile:
Now that you know the K-value is 200 N/mm, what must the applied force be in the second instance, when you know the stretching is equal to 2.0 mm?
anthonyk2013
125
F=k*x
F=200*2=400N/mm squared ?
arildno
Dearly Missed
10,025
135
How does (N/mm)*mm become?
anthonyk2013
125
Need to concentrate no mm.
400N
arildno
Dearly Missed
10,025
135
Yup! :smile:
arildno
Dearly Missed
10,025
135
Now, here's how you can do it without bothering to solve for "K" first:
We have, for the first instance, F_1=k*x_1
and for the second instance, F_2=k*x_2
Dividing the second equation by the first, we have:
F_2/F_1=(k*x_2)(k*x_1)=x_2/x_1
That is:
F_2/F_1=x_2/x_1, or, multiplying with F_1
F_2=(x_2/x_1)*F_1
anthonyk2013
125
That is:
F_2=(x_2/x_1)*F_1
Thanks very much for your help. I won't feel too bad in class Thursday evening.
Cheers
Suggested for: Confused which formula to use
  • Last Post
  • Last Post
  • Last Post
  • Last Post
