Homework Help: Confusing Chem
  1. Sep 9, 2010 #1
    25 cm3 of 1 mol/dm3 ethanoic acid requires a smaller amount of sodium hydroxide for complete neutralisation than 25 cm3 of 1 mol/dm3 hydrochloric acid.
    True or False?
    2. The attempt at a solution
    I selected true, but I was wrong. Both of them require the same amount of sodium hydroxide. How can this be?
    Question 2:
    In a dilute sugar solution, sugar molecules are widely separated, moving at random while water molecules are close together, moving at random.
    True or False?
    Attempt
    I selected False. But I was wrong AGAIN! What's the reason?
    Could you all help me with my questions. Thanks!
  3. Sep 9, 2010 #2
    Borek
    Staff: Mentor
    Why do you think they need different amount of base?
    Similarly, try to explain your reasoning behind the answer to the second question.
  4. Sep 9, 2010 #3
    I think they need different bases cause ethanoic acid is a weak acid while HCL is a strong acid, thus you need more NaOH to neutralise a strong acid than a weak acid.
    I figured out the second qns though, but I remember a qns vaguely about alcohol being dissolved into water and the mixture seems to have mass that didn't add up to the mass of water and alcohol or something like that. I didn't know whether it is the mass, density or volume that didn't add up.
  5. Sep 9, 2010 #4
    Borek
    Staff: Mentor
    Write reaction equations both for HCl and acetic acid neutralization with NaOH.
    How much base needed to neutralize 1 mole of each acid?
    Volume is not additive. Mass is additive, that's mass conservation in action. But I fail to see how volume being not additive is relevant to the question.
  6. Sep 9, 2010 #5
    Both require 1 mole... But even if both acids have 1 mole of particles, HCL would have more hydrogen ions since ethanoic acid dissociates partially and there would be CH3COOH molecules left intact in the water.
    I figured out qns 2. Thanks.
  7. Sep 9, 2010 #6
    Borek
    Staff: Mentor
    You are mistaking dissociation with neutralization. Yes, pH of HCl solution is lower than pH of acetic acid solution, no, it doesn't mean it requires more base for neutralization.
