Homework Help: Confusing force problem
  1. Sep 12, 2008 #1
    Here is a picture of the problem.
    The question is:
    A force F0 causes an acceleration of 17 m/s2 when it acts on an object of mass m sliding on a frictionless surface. Find the magnitude of the acceleration of the same object in the circumstances shown in each figure below.
    Figure (a)
    m/s2
    Figure (b)
    m/s2
    My problem is Im not too sure what the problem wants me to do.
    It gives me the acc. of 17 m/s^2 but how come it asks me to find the magnitude of the acc.?
    Can somone please rephrase this into simpler terms? I want to do this on my own but Im just confuse on what this problem want me to do. Any help would be appreciated.
  3. Sep 12, 2008 #2
    It sounds to me like the problem just wants you to deal with vectors. Your right in that it is not a very well written problem. I believe the author is referring to a 17 m/s^2 acceleration if the force Fo is applied in a single direction.
    For diagrams a and b the force Fo is acting in multiple directions and your job is to find the resulting acceleration due to Fo acting in those different directions.
  4. Sep 12, 2008 #3
    Doc Al
    Staff: Mentor
    17 m/s^2 is the acceleration of the mass when only one force Fo acts by itself. (You'll need this fact later.) When multiple forces act, as shown in the diagrams, the net force and thus the acceleration will be different.
    Hint: Find the net force in each diagram in terms of Fo.
  5. Sep 12, 2008 #4
    So it accelerates an object 17m/s^2 when 1 Fo is applied.
    Diagram 1 shows 2 Fo, 1 pushing horizontally and 1 vertically.
    Im assume they are pushed simultaneously, so wouldn't the object move
    at an angle of 45 degrees? or in the middle?
    Would I need to find that magnitude?
    So I would need to find the vertical and horizontal component, but the Force of Fo is not given nor the mass so, is it 17m/s^2, the components?
  6. Sep 12, 2008 #5
    Doc Al
    Staff: Mentor
    Right.
    Yes.
    Absolutely.
    Find the magnitude of the net force as a multiple of Fo. Then you'll be able to compare that force to the one that gives you a 17 m/s^2 acceleration.
  7. Sep 12, 2008 #6
    Im not quite sure what I should do with so little info the problem gives me.
    I have to find the "hypotenuse" in the triangle it forms with the angle 45 degrees.
    I know the horizontal and vertical component is Fo.
    Then I go blank on what to do next.
  8. Sep 12, 2008 #7
    Doc Al
    Staff: Mentor
    If the sides of the triangle were 10 units long, what would be the hypotenuse? Then answer the question if the sides were Fo units long.
  9. Sep 12, 2008 #8
    I think I got it.
    Is the first 1
    root of(Fo^2 + Fo^2)
    root of(2Fo^2)
    square root(2) * F0
    Then root(2) * 17 m/s^2
    and the 2nd 1 is
    square root(5) * F0
    Is this correct?
  10. Sep 12, 2008 #9
    Redbelly98
    Staff Emeritus
    Yes.
    Not quite. The two vectors are not at right angles, so the Pythagorean Theorem does not apply.
    Try using trig to express the forces in terms of x- and y-components.
  11. Sep 12, 2008 #10
    I split it in half so each angle is 22.5
    so is sin22.5x = F0
    x = 17m/s^2 / sin22.5
    Is this approach good?
  12. Sep 14, 2008 #11
    Doc Al
    Staff: Mentor
    No. The trick of going down the middle works when the forces are equal, as in the first example, but not when they are unequal. Instead, call the direction of the 2Fo force the x-direction. Now find the x and y components of both forces and then the resultant. Then you can use the Pythagorean theorem to find the magnitude of the net force.
  13. Sep 17, 2008 #12
    I'm having difficulty with this same question (although my Fo has an acceleration of 16m/s^2). I understand how to find the magnitude of the acceleration for diagram a, but still don't understand how to go about breaking into components of x and y for diagram b. Can anyone explain further? Thanks!
  14. Sep 17, 2008 #13
    Doc Al
    Staff: Mentor
    Call the direction of the 2Fo force the x-direction. So, what's the x & y components of the 2Fo force? And the x & y components of the other force, which is at a 45 degree angle to the x-axis?
    (This is just like finding the components of any other vector.)
  15. Sep 17, 2008 #14
    Thanks Doc Al,
    I just tried what you said and understood where I was going wrong. I wasn't separating the forces into 2 separate components, but rather tried solving with them together. After following your instructions, I got the answer right! Thanks for your help!
