Solve Confusing Pattern: 10,17,26,37,50,65
In summary, the given sequence follows an arithmetic pattern with a common difference of 7, where each number is obtained by adding 7 to the previous number. The formula to calculate the next number in the sequence is n<sub>n+1</sub> = n<sub>n</sub> + 7, where n<sub>n+1</sub> is the next number and n<sub>n</sub> is the current number. The 10th number in the sequence is 100, which can be found using the formula n<sub>n</sub> = a + (n-1)d. This pattern can be extended to negative numbers and can be applied in real-life situations such as calculating interest rates or predicting
dougb
these pattener are cofusing please help i coml=pleted the first one
10,17,26,37,50,65
1,3/2, ____, 7/8, 9/16
243, 324, 403, _____, 567
234;________; 23,481; 234,819; 2,348,200.
Mathematics news on Phys.org
10,17,26,37,50,65
http://www.research.att.com/%7Enjas/sequences/
That is the bible for pretty much every pattern in existence. Check it out and book mark it. I always find it very useful every once in a while.
The second and third are trivial and you should really try a little harder to find the patterns.
For the last one, study how digits are appended to the right.
What is the pattern of the given sequence?
The pattern is an arithmetic sequence with a common difference of 7. Each number is obtained by adding 7 to the previous number.
What is the formula to calculate the next number in the sequence?
The formula is:
nn+1 = nn + 7
Where nn+1 is the next number in the sequence and nn is the current number.
What is the 10th number in the sequence?
The 10th number in the sequence is 100. To find this, we can use the formula nn = a + (n-1)d, where a is the first term (10), n is the term number (10) and d is the common difference (7).
n10 = 10 + (10-1)7 = 10 + 9(7) = 10 + 63 = 73
Can this pattern be extended to negative numbers?
Yes, the pattern can be extended to negative numbers. The formula to calculate the next number in the sequence remains the same. For example, the sequence can be extended as -3, 4, 13, 24, 37, 52...
How can this pattern be applied in real-life situations?
This pattern can be applied in various real-life situations such as calculating interest rates, predicting population growth, or determining the distance covered by a moving object at regular intervals of time.
  • General Math
