Demystifying Quantum Numbers: Understanding the Role of n, l, and ml
In summary, the principle quantum number, n, corresponds to the period of the element in the periodic table. It indicates the energy level and distance from the nucleus of the valence electrons. The "n" value can also determine the possible subshells and orbitals for electrons in an atom. However, not all elements in a specific period will have electrons in all possible subshells. In the case of Zr, which has an atomic number of 40 and is in the 5th period, it can have electrons in its 5d subshell (n=5, mℓ=3), but not in its 5g subshell (n=5, mℓ=4). This is due to
Modernization
I am still totally confused about the principle quantum number even though i got passed the unit with a A+ on the exam. does the principal quantum number, n, have anything to do with the period? Does the "n" value, which leads to the "l" and "ml" actually indicate all the possible orbitals for a particular atom or just for one electron. When you give an "n" value of 4, what does that mean? does it mean any element on period 4?
Also, why couldn't element Zr (atomic number=40) have at least one electron with an "ml" value of +4?
thanks
Yes! 1st period - n=1, 2nd period - n=2. And so on. BUT - that relates only to the valence shell. All valence electrons in all atoms form 3rd period have n=3, but these atoms have also electrons with n=1 and n=2, they are just not taking part in reactions. (In the case of of periods with higher numbers it can get a little bit more cimplicated, but for now that should be enough).
There are many electrons having the same n value, so it probably means "all", but I am not sure what the question is.
No, any atom of any element from period 4th up can have electrons with n=4.
Because for n=4 maximum value of ml is 3. To misquote Pauli - treat it as a police ban. You don't have to understand, but you have to obey :wink: There is a logic behind, but it is hard to understand without knowing more about where and how quantum numbers appear in wuantum mechanics.
but the element Zr is on the fifth period, so wouldn't it have an "n" value of 5, which makes ml +4 possible?
Sorry, my mistake. You are right, 5th period it is. But now I am not sure what you are asking about.
An n value of 5 means that an element can have a maximum mℓ value of 4, but an element with electrons in its n = 5 shell doesn't automatically mean it has electrons in all its subshells, or in this case, electrons in its 5g subshell (n = 5, ℓ = 4). Zr (element 30) just has enough electrons to reach its 5d subshell (n = 5, mℓ = 3). On the other hand, no element on the periodic table has enough electrons to reach the 5g subshell (n = 5, ℓ = 4) in its ground state.
By my figuring, the first element to have an electron in its 5g subshell would be element 121.
What are quantum numbers?
Quantum numbers are a set of numerical values that are used to describe the energy levels and properties of an electron in an atom.
How many quantum numbers are there?
There are four quantum numbers: the principal quantum number, the angular momentum quantum number, the magnetic quantum number, and the spin quantum number.
What is the purpose of quantum numbers?
Quantum numbers are used to identify the specific location and energy level of an electron in an atom, as well as its spin and orientation in space.
Why are quantum numbers sometimes confusing?
Quantum numbers can be confusing because they are not physical properties that can be easily visualized, but rather mathematical representations of the energy and properties of electrons in an atom.
How are quantum numbers determined?
The principal quantum number is determined by the energy level of the electron, while the other quantum numbers are determined by the shape, orientation, and spin of the electron's wave function.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
