Confusion about the Lorentz force
In summary: The integral I evaluated was:$$\int\limits_{0}^{R}\int\limits_{0}^{\pi/2}\int\limits_{0}^{2\pi} \rho \sin{\theta} d\phi d\theta dr$$The force on a charge located at (x,y,z) in a hemisphere isIn summary, the force on a charge located at (x,y,z) in a hemisphere is calculated by finding the E-field on the charge first, then applying the Lorentz force formula. However, it is not clear to the author how to find the E-field, and if the charge were on top of the
Silicon-Based
51
Member advised to use the formatting template for all homework help requests
We can find the force by finding the E-field on the charge first, then applying Lorentz force formula. However, it isn't obvious to me at all how to find the E-field. If the charge were on top of the hemisphere I would be using spherical coordinates, but here I don't know which coordinate system to even use.
What happened to the template ?
You'll need a few equations to get started.
If I were you, I'd use spherical coordinates with the center of the hemisphere as center and the hemisphere in ##\theta\le 0##
Could you elaborate on that? How could I do that to then find the E-field at the point where the charge is?
Actually, you should be the one to do that ! You want to set up an integral of something like ## {dq \over r^2} = \rho {dV\over r^2}##
Since we chose the coordinate system so nifty, there is only one component of interest. What is ##dV## in terms of spherical coords ?
I believe it should be ##dV=r^2 \sin{\theta}d\phi d\theta dr##
Keep going.
I still don't see where this is going. I integrated for ##Q## and got ##Q=2\pi R \rho r^2##, if that's in any way helpful. Regardless of weather this is right or not, this would give me the total charge of the hemisphere, but I don't see how I'm supposed to use it to find the force; we can't treat the hemisphere as a point particle.
I suggest you go back to the start, and forget about spherical coordinates until you have successfully set up the correct integration. Then, and only then, can you decide if spherical coordinates are helpful.
So, you have a lot of little charges ##dQ = \rho dV## at positions ##(x,y,z)## in the hemisphere. The ##z-##component of force on the test charge due to charge ##dQ## at ##(x,y,z)## is
$$ dF_z = k q \rho \, \frac{dx \, dy \, dz}{x^2 + y^2 + (d-z)^2}.$$
This is to be integrated over the 3-dimensinal region ##\{ 0 \geq z \geq -\sqrt{R^2 - x^2 - y^2} \}##.
WARNING: the above is not quite correct---I made an error. I will leave it up to you to figure out what changes are needed.
Here Ray has already leaked that the net force on q is in the z direction. No big secret: symmetry in ##\phi## (i.e. around the ##z##-axis) does that for you.
To be frank, I've been only exposed to derivatives of polar coordinates. These are the ones that come up in E&M most of the time. So it's actually easier for me to set up the integration with spherical coordinates in mind. Moreover, it's obvious some offshoot of those need to be used, given the hint below the question.
Not really; I just talked about the ##z##-component of the force.
However, what I wrote is not quite correct! The OP can figure out how to fix it.
I miss where the ##r^2## went: you gave the correct ##dV=r^2 \sin{\theta}d\phi d\theta dr## so that Q comes out as a much more sensible ##{2\over 3} \pi \rho R^3##
Ray Vickson said:
Not really; I just talked about the zzz-component of the force.
I stand corrected. :smile:
Silicon-Based said:
To be frank, I've been only exposed to some derivatives of polar coordinates. These are the ones that come up in E&M most of the time. So it's actually easier for me to set up the integration with spherical coordinates in mind. Moreover, it's obvious some offshoot of those need to be used, given the hint below the question.
Yes, sorry for the distraction that went on over your head.
Sketch how a small volume of charge at ##r,\theta## (e.g. in the x,z plane) generates an ##\vec E## at the position of q.
I don't see how you got this; you need more explanation.
BvU said:
I miss where the ##r^2## went: you gave the correct ##dV=r^2 \sin{\theta}d\phi d\theta dr## so that Q comes out as a much more sensible ##{2\over 3} \pi R^3##
I must have misinterpreted your earlier post:
If I were to keep ##r^2## in the integrand, I'd get the right answer.
Sketch how a small volume of charge at ##r,\theta## (e.g. in the x,z plane) generates an ##\vec E|## at the position of q.
Well, if ##r## is the distance from the charge, and ##\theta## the angle between ##r## and the ##z##-axis, the E-field due to a small charge is given by ##dE=k\frac{dQ}{r^2}##, so to find the E-field in the desired direction, we have ##dE_z=k\frac{dQ}{r^2}\cos{\theta}##
As before, in response to BvU. If I were to keep ##r^2## in the integrand, I would get the right answer.
Doesn't ##r## change when you change the location ##(x,y,z)## of the source charge ##\rho \, dV?## Because of the way you wrote the force expression, I thought that ##r## was the distance from the test charge ##q## at ##(0,0, d)## and the source charge at ##(x,y,z)##. Of course, maybe you want ##r## to be the distance from the origin to ##(x,y,z),## but in that case you need a new distance ##r' = \sqrt{x^2 + y^2 + (d-z)^2}## in the force expression.
Or, are you claiming that the field at ##(0,0,d)## is the same as that of a point charge ##Q = \rho V##, located at the origin? I have serious doubts about that.
It is true that the field due to a uniformly charged sphere (or spherical shell) is the same as for a point charge located at the center, but a hemisphere is not a sphere.
Note added in edit: it might help you to look at the answer in
https://physics.stackexchange.com/questions/363196/charged-hemisphere
Yes, that was for the ##\vec E## already, (with a different ##r## !)
Make the sketch. You'll need to distinguish several ##r##.
Thread moved from the technical forums, so no Homework Template is shown
The following is a past exam question on electrostatics:
And here is my (correct) solution:
I understand the derivation of the E-field at the centre of the flat surface of the hemisphere, but I don't see the justification for using it in the Lorentz force formula. Is one not supposed to use the Lorentz formula for the charge and the E field at the same point in space, not a distance d away? The resulting formula has no spatial variable, which would imply that placing the charge on the same axis but at a large distance away from the hemisphere would result in the exact same force (while it obviously should decrease with distance).
You haven't set up the integral correctly. As you said, you want to calculate the E-field where the charge is. In your integral, you are summing up the contribution of each infinitesimal packet of charge at location (r, theta, phi) to the field at the point where the charge is. To do this, the 1/r^2 term in your integrand is the distance from the charge to the point in the charged sphere. So it needs to contain the distance d. What is the distance from the point charge to the point in the charged sphere in terms of d, r, theta and phi? Also, you need to sum up each component of E separately, or use symmetry arguments to explain why some components of E might be zero.
My solution is correct. I should not find the E-field at the point where the charge is, that would be far beyond my abilities. This solution is pretty much the model solution for that question (I dicussed it wih the examiner himself), but now the examiner refuses to respond to my email to clarify my concern in question.
I agree with phyzguy's comments. You found the field at the center of the hemisphere, not at a distance 'd' above that center.
So it's my electromagnetism course that is messed up? Great... supposedly the best university in Europe, and it can't get a freshman EM course right.
Why would it be "beyond you capabilities"? You've already set up an integral and evaluated it. You just need to make a modification. If you're taking an EM course at " the best university in Europe", you should be able to calculate the distance from the point d above the center to a point (r, theta phi). It is simple geometry. If you can't do that, I would suggest that it is not your course which is "messed up".
Look, this is THE MODEL SOLUTION that I cosulted with the examiner who made up this question himself. I'm asking for a clarification of one of the steps.
As for the approach you suggest, this is far from simple geometry. I tried to solve it that way for at least 2 weeks, consulting various forums and people, until I had to get in contact with the examiner himself. I'm not supposed to be using anything beyond simple cathesian coordinates, or spherical/cyllindrical coordinates.
By your own questions, I think you realize that this solution cannot be correct, despite what the examiner says. Is he the professor for the course or a teaching assistant? When you consulted with him, did you ask why the answer did not depend on the distance "d"?
He's the lecturer of the course. I tried to inquire about that exact detail at that time but I was still partly in the process of digesting the integration. I have hence tried to get in touch with the examiner again (by email, his lecture course ended) but he did not reply to me yet.
Update: the examiner has just responded to me, and indeed, he made a mistake; there should be no spatial separation between the charge and the centre of the hemisphere.
Very good. Sanity has been restored. (I'm glad he owned up!)
1. What is the Lorentz force?
The Lorentz force is a fundamental force in electromagnetism that describes the interaction between electric and magnetic fields on a charged particle. It is named after Dutch physicist Hendrik Lorentz who first described it in the late 19th century.
2. How does the Lorentz force affect charged particles?
The Lorentz force causes a charged particle to experience a force when it moves through a magnetic field or when it is in the presence of both electric and magnetic fields. This force is perpendicular to both the direction of the particle's motion and the direction of the magnetic field.
3. What is the equation for the Lorentz force?
The Lorentz force is calculated using the equation F = q(E + v x B), where F is the force, q is the charge of the particle, E is the electric field, v is the velocity of the particle, and B is the magnetic field.
4. What are some real-life applications of the Lorentz force?
The Lorentz force is responsible for many phenomena in our everyday lives, such as the operation of electric motors and generators, the functioning of particle accelerators, and the behavior of charged particles in the Earth's magnetic field.
5. How does the Lorentz force relate to special relativity?
The Lorentz force is a key component of special relativity, which describes the behavior of objects moving at high speeds. It is used to explain how electric and magnetic fields transform when observed from different reference frames and how this affects the motion of charged particles.
