"Finding Smallest n for Congruence Modulo Homework
  • Thread starter shizukusan
In summary, the smallest positive integer that satisfies all the given congruences is 251. This can be determined by starting with the first congruence and incrementing by 2 until the congruences are satisfied. This process yields the numbers 3, 5, 13, 21, 29, 37, 45, 53, 61, 69, 77, 85, 93, 101, 109, 117, 125, 133, 141, 149, 157, 165, 173, 181, 189, 197, 205, 213, 221, 229, 237, 245, and finally,
shizukusan
Find, with proof, the smallest positive integer n that satisfy all the congruences.
n = 1 (mod 2)
n = 2 (mod 3)
n = 3 (mod 4)
n = 4 (mod 5)
n = 5 (mod 6)
n = 6 (mod 7)
n = 7 (mod 8)
n = 8 (mod 9)
n = 9 (mod 10)
Let a,b,m within Z with m > 0. Then, a = b mod m is m|a-b.
(not sure if relevant or not)
I tried to figure out what some of the ristriction on n
(ie - has to be odd since n = 1 (mod 2))
but didn't get too far.
The first congruence tells you that n must be odd. If you try odd numbers, starting from 3, on the other congruences, what do you get?
I sort of tried that approach using the other ristrictions but started to get into the 400s. (with only considering 3 of the 9 ristrictions).
plus, I need to provide a proof and this way is probably not going to work as a proof.
400 is hardly a large number :smile:.
Look, if you want strictly positive integers, the smallest that satisfy the first congruence is 3. Now, the smallest that satisfies the first two is 5. Now, what is the smallest that satisfies the first three?
When you get to the last one, you will have the smallest that satisfies all; the steps are a valid proof.
1. What is congruence modulo?
Congruence modulo is a mathematical concept that defines the relationship between two numbers that have the same remainder when divided by a third number. This is denoted by the notation "a ≡ b (mod m)", where "a" and "b" are the two numbers and "m" is the third number.
2. Why is finding the smallest n for congruence modulo important?
Finding the smallest n for congruence modulo is important because it allows us to simplify complex equations and make calculations easier. It also helps us to identify patterns and relationships between numbers.
3. How do you find the smallest n for congruence modulo?
To find the smallest n for congruence modulo, you can use the Division Algorithm. First, divide the larger number (a) by the smaller number (b) to get the quotient (q) and remainder (r). Then, set up the equation "a ≡ r (mod b)". Finally, solve for "n" by adding or subtracting multiples of b from r until you get the smallest positive value.
4. What are some common mistakes when finding the smallest n for congruence modulo?
One common mistake is forgetting to use the Division Algorithm and instead trying to solve the equation directly. Another mistake is not considering all possible values for n, which can lead to incorrect answers.
5. How is congruence modulo used in real-world applications?
Congruence modulo has many applications in fields such as cryptography, computer science, and number theory. It is used in encryption algorithms to secure data, in error detection and correction codes, and in finding prime numbers. It also has applications in engineering, physics, and chemistry for solving equations and predicting patterns.
