Conjecture about primes
  • Thread starter dodo
Let p,q be two different primes from 5 onwards (not 2 or 3). Let p be the biggest of the two.
The difference of squares p^2 - q^2, since p,q are both odd, is always a multiple of 8 (easy to prove). So take the integer k = (p^2 - q^2) / 8.
It turns out that k seems to be (says friend computer) a multiple of 2 or a multiple of 3, or both. I can't find an example where k is divided neither by 2 nor by 3.
Example: p=53, q=31. p^2 - q^2 = 1848 = 8 * 231. And 231 is divisible by 3.
If p and q were not primes, but just odd and coprime, then counterexamples abound. (I use coprimes because, had they a factor in common, one could produce k as a multiple of anything.) For instance: p=45, q=31. p^2 - q^2 = 1064 = 8 * 133; and 133 is not divisible by 2 nor 3.
Any hint as of why would it work only with primes (>= 5)? Or a counterexample?
EDIT: Doh, forget it. It has to do with the numbers being 6n+1 or 6n-1. (If any mod can delete this thread I would be less embarrased.)
Answers and Replies
Hurkyl
Staff Emeritus
I'm assuming you're familiar with modular arithmetic -- any two odd numbers have the same square modulo 8.
If k is again divisible by 2, then you are asserting any two odd primes square to the same thing modulo 16. And if k is divisible by 3, you are asserting that any two odd primes square to the same thing modulo 3.
Using modular arithmetic, it should be easy to prove that k is divisible by 3, and to find an example where k is not divisible by 2.
(aside: if m is relatively prime to n, then there are infinitely many prime numbers equivalent to m modulo n)
Related Threads on Conjecture about primes
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
