Connecting the primary and secondary windings of transformer in series
In summary, connecting the primary and secondary of a transformer in series can result in different fluxes and potentially violate the intended purpose of the transformer. This can lead to the need for additional counter flux and potentially affect the current flow in the circuit. However, if the source of power is a battery, no transformer action will take place as transformers do not work with direct current.
kmarinas86
979
What happens if you connect the following in this order:
1) from a battery to the primary in
2) from the primary out to the secondary in
3) from the secondary out to a motor
4) from the motor to the battery
I know that transformers usually step up or step down the voltage, but it shouldn't be possible to feed a stepped up voltage and add it to the total voltage right? So what would REALLY happen?
Say if it was a step up transformer, the voltage would go up and the current would go down. But in my example, the current that goes through the primary windings would also go through the secondary windings. This complicates things I know, but does anyone have a good answer as to what would happen? Thanks.
I believe you've just made your transformer a very long piece of wire.
A transformer works on the principle of inductance. i.e. A CHANGE in magnetic flux though a loop of wire will cause a current to flow in the loop. So the transformer must see a voltage that VARIES with time (alternating current) inorder for there to be induction. Now with your set-up, you have a "steady" voltage from the battery (direct current) so you will not see the motor working any different from just having long wire attached as LURCH wrote.
That being said; if you are using a motor with bruches, then there may be some small voltage spikes produced from arcing which may cause a little induction.
If you are really interested in learning how transformers work, then check out http://en.wikipedia.org/wiki/Transformer" .
Regards
Depending on the polarity of how you connect the primary to the secondary, I believe you will either see the sum of the magnetizing inductances of the primary and secondary (Lmp+Lms), or the sum of the leakage inductances (Lkp+Lks). Can you tell us why?
EDIT -- I think this statement of mine above is incorrect, at least for the coupled inductors on the same coil:
"I believe you will either see the sum of the magnetizing inductances of the primary and secondary (Lmp+Lms"
No.
But even if I put same current through both the primary and the secondary, wouldn't the difference in windage create a difference in voltage between them (because of transformers ability to direct magnetic flux from the coils)?
kmarinas86 said:
No.
It sounds like you are a bit confused about how transformer action works. Try reading through this recent thread to see if it helps:
https://www.physicsforums.com/showthread.php?t=187441
Flux produced by primary must be canceled by flux produced by secondary. This is how a transformer works.
Flux = Number of turns * I
So the winding which have more turns must have less current.
So what if I did not want to work with my transformer as intended? Let's assume for the sake of argument that the following is safe, so we can focus on what happens if we, "Connect the primary and secondary in series when they have different numbers of turns."
Fact: When the primary and secondary have been become part of the same circuit and are connected in series they would be required to have the same current (per previous information handed to me in this forum).
Fact: If the current is the same between them, then the primary and secondary (previously assumed to have different numbers of turns) will have different fluxes. This violates the intended purpose of a transformer.
Fact: If the fluxes are different, there would have to be additional counter flux, corresponding to the circuit current times the difference in the number of turns between the primary and the secondary.
Question: What happens if the primary and secondary windings are connected in series where the ends normally associated with output are connected to each other through the load?
Visual for the following underlying questions: "+" of voltage source ----wire---- Intended entry point of secondary winding ----wire---- Intended exit point of secondary winding ----unspecified load---- Intended exit point of primary winding ----wire---- Intended entry point of primary winding ----wire---- "-" of voltage source
Underlying question A: What happens to the current in the backwards oriented primary if current moves forward from the forward oriented secondary into the load?
Underlying question B: What happens to the current in the forwards oriented secondary if current moves forward from the backwards oriented primary to "-" of the voltage source?
Your first post said "...from a battery...". If the source of power is a battery, then no "transformer action" will take place. The effect will be the same as if you simply unwound all the wire from the transformer and put it in series with your battery.
Transformers don't "step up" or "step down" direct current, which is what you get from a battery.
Then I am not talking about a direct current source anymore.
Question: What happens if the primary and secondary windings are connected in series where the ends normally associated with output are connected to each other directly?
Underlying question A: What happens to the current in the backwards oriented secondary if current moves forward from the forward oriented primary into the backwards oriented secondary?
Underlying question B: What happens to the current in the forwards oriented primary if current moves forward from the backwards oriented secondary to the load?
If you connect the two windings in series, you either add their effects, or they partially cancel each other's effects. The inductance goes as the number of turns squared, so if the two coils have the same number of turns, you either get 4x the inductance (I was wrong above when I said Lmp+Lms -- that's only true for non-coupled inductors), or zero inductance (actually Lkp+Lks), depending on the polarity of the series connection. You are correct that the current in the series coils has to be the same, and the flux in the core seen by each coil is the same
Thanks. Now to examine a specific series connection more closely:
kmarinas86 said:
Visual for the following underlying questions: "+" of voltage source ----wire---- Intended entry point of secondary winding ----wire---- Intended exit point of secondary winding ----unspecified load---- Intended entry point of primary winding ----wire---- Intended exit point of primary winding ----wire---- "-" of voltage source
Now for the questions:
kmarinas86 said:
Underlying question A: What happens to the current in the forwards oriented primary if a surge of current moves forward from the forwards oriented secondary into the load?
According to my knowledge, this would create a potential difference from the load into the "-" of the battery.
kmarinas86 said:
Underlying question B: What happens to the current in the forwards oriented secondary if a surge of current moves forward from the forwards oriented primary to "-" of the voltage source?
According to my knowledge, this would create a potential difference from the "+" of the battery into the load.
kmarinas86 said:
Underlying question C: If you put a volt meter between the exit point of the secondary and the load of this circuit, would the voltage correspond not only to the voltage source but also to the turns of wire when current is also passing through the forward oriented secondary (i.e. would the voltages add when current is moving throughout all of the circuit)?
According to my knowledge, the transformers should not be able to increase voltage without reducing the current usage, yet is seems like the original current from the batteries can be used to add to the load with the seeming prospect of circuit voltage gains from the transformer. What assumptions am I missing?
This cries out for an experiment. Buy a 12 V CT transformer from DigiKey and use a short-proof power supply for the battery. Let us know what you found out.
I already bought a 70 volt constant voltage transformer (rated at 4 watts) from http://www.fullcompass.com/product/303987.html
I plan to use it in my motor as soon as it ships in. I already have a multimeter in which I can test the current and voltage going into it.
That's an audio transformer and probably not what you want to run any kind of motor circuit. I also don't think it is a constant voltage transformer; those use ferroresonance and I can't imagine doing that in an audio unit (unless you like the hum "Say, why does your speaker hum?" "Cause it doesn't know the words.":rofl:)
What exactly are you trying to accomplish in terms of this motor? A whole bunch of us on here have a lot of experience and would be glad to point out some ways to achieve your goal.
In general, most times you run dc through a transformer, it quits being a transformer because you have saturated the core and now have a permeability near air. The only way around that is to use balanced "bucking" dc currents (thus my suggestion you buy a CT unit where you can do that).
The Quam TBLU / TBL25 / TBH70 / TBL70 / TCL70 is a
constant voltage line transformer with multi-tap inputs.
I have a mechanical commutator so I will get varying current and voltage going into the primary windings one I get this transformer.
If you connect the primary and secondary as you have described, then you will have converted the transformer into an inductor. It will not be a very good inductor. The core will saturate sooner than you would expect with a purpose-designed inductor, because when it was used as a transformer, the flux caused by the primary and secondary tended to cancel, but this effect is not nearly so pronounced when it's wired as an inductor. You would need to introduce an air gap in the core assembly if you wanted it to be a good inductor.
Even if you use a mechanical commutator to convert the DC from the battery into pulsating DC, which will therefore have an AC component, whatever voltage "step up" or "step down" may be going on internally between the windings will not be apparent outside the rewired transformer. You will have nothing more than an inductor in series with the motor and commutator. The inductor will provide opposition (impedance) to the current, and will decrease the effective voltage applied to the motor.
The pulsating DC caused by the commutator will have an equivalent DC component and AC component, unless the commutator is wired as a bridge, in which case there won't be a DC component. Then the AC component will just be a square wave AC voltage. But if there is a DC component, the inductor (rewired transformer) will saturate easily, and when it does, its inductance will decrease, perhaps a lot, and the remaining effect will be just the resistance of the wire in the windings in series.
If you tell us what you're trying to accomplish, we may be able to give you suggestions that will more directly get your desired result.
I am aiming for better for better motor output than what I have right now. I rate this as that the product of rpms, torque, and time I can use to run the rotor (permanent magnet) from a battery power supply. Now the voltage in the transformer is a function of how fast the magnetic field changes. The faster the circuit is opened and closed by the commutator, the higher this voltage will be, and the turns do not change. I intend to somehow take current from the batteries and push the majority of them through the entire coil, instead of just the primary windings. I am trying to avoid the situation of limited current at the secondary windings. At the same time, I want someway to take advantage of the transformer's ability to produce voltage. However, I do not understand if it is possible to increase the voltage as readily if the current in transformer is forced to be the same in both in the primary and the secondary. However, even the tiniest increase in voltage in the secondary going into the coil would help to improve the efficiency of the motor.
It sounds to me like you want to increase the voltage applied to the motor to be above what is available from your battery. Is that what you want?
If this is so, why can't you just use a higher voltage battery? If you can't do that, then you will have to use a DC-DC converter. If you do that, the audio transformer you ordered will not be suitable for the purpose.
See:
http://en.wikipedia.org/wiki/DC_to_DC_converter
http://www.powerdesigners.com/InfoWeb/design_center/articles/DC-DC/converter.shtm
I think the meaning of the phrase is that it is a line transformer which is meant to be driven at a constant voltage. Once long ago, when the world was still young, I used those to drive horn speakers at public events.
The commutator will certainly help, but you will have to watch the frequency. Remember that the back end of a square wave is about 0.1 the fundamental frequency.
The idea of adding windings in addition or subtraction certainly works ("buck-boost" line transformers do this all the time), but you're always stuck with a power output that is less than the power input (somewhere between maybe 80% and 99%).
I think the point that might be throwing you off is the idea that it is current that causes the magnetic flux in a transformer core. In fact, as noted earlier by others, you should look at a transformer in terms of the flux being proportional to the changing voltage. There are typically three currents then that you see: a magnetizing current; a losses current; and a load current. The load current, which is what flows through your motor, is pretty much irrelevant to the core (or at least should be).
Can you provide a sketch of what you're doing?
Here you go.
kmarinas86 said:
Here you go.
Ok, thanks. What you have shows that the current through the transformer more or less stays constant (never reverses). The core will saturate and effectively "disappear". So, as somebody pointed out, you now have a long wire. A transformer is really only useful as an impedance matching device, that is, it trades voltage for current or vice-versa. It never gives you more power.
Not sure about the reversing. The commutator open and closes the pathway as the rotor rotates. So I would expect the current signal to be somewhat of a square wave. The current is obviously not going to be constant as a function of time, but only constant as a function of distance through the wire, I believe, and that's what matters as far as the change of magnetic flux through the different windings are concerned.
Although the amplitude of the square wave would be limited by a maximum (depending on the current source), the rate change of magnetic flux in transformer windings will change with the acceleration and deceleration of current each time the connection is made. The waves are complicated however; if the peak acceleration of the current occurs after a small fraction of the total charge for that connection has passed through, the speed of the rotor (i.e. the reduction of connection times) may have little to do with the peak acceleration of current that leads to the greatest rate change of magnetic flux. However, if the connection is cut off before the current can accelerate to its maximum, then the effective rate change of magnetic flux (voltage produced) is not as high.
I guess only experiment will show what exactly happens. Sending 1 amp in and out of the secondary winding when transformer is rated at 70 volts and four watts may have some weird results, especially when the current spike passes through the primary windings affecting the current behind it in some way. These feedback effects, I believe would have an effect on the distribution of charges, but not so much the current passing through the large coil. Since mass flow rate = velocity of masses * linear density of masses, I would expect similar things for charges.
The current is obviously not going to be constant as a function of time, but only constant as a function of distance through the wire, and that's what matters as far as the change of magnetic flux through the windings are concerned.
'Tis the voltage, Katie Scarlett, 'tis the voltage.
Oops. Lost the quote part of the first paragraph.
Hey guys,
You cannot connect the primary and secondary of a transformer "in series". The voltage boosting aspect of the transformer will not function. The secondary discharges an 'inducted' voltage based on the COLLAPSING MAGNETIC FIELD when the current to the primary coil is cut. THE PRIMARY AND SECONDARY ARE NOT ELECTRICALLY CONNECTED! Although sometimes they share a ground, a true isolation transformer has not electrical connectivity between primary and secondary.
Good luck
1. How do you connect the primary and secondary windings of a transformer in series?
To connect the primary and secondary windings of a transformer in series, you will need to have two transformers with matching voltage ratings. Then, you will connect the primary winding of one transformer to the secondary winding of the other transformer, creating a continuous loop.
2. Why would you want to connect the primary and secondary windings of a transformer in series?
Connecting the primary and secondary windings of a transformer in series allows you to increase or decrease the voltage output. This is useful in situations where the input voltage does not match the desired output voltage.
3. What are the potential risks of connecting the primary and secondary windings of a transformer in series?
One potential risk is that the transformers may not have matching voltage ratings, causing an imbalance and potentially damaging the transformers. Another risk is that the transformers may not be properly connected, resulting in an incorrect voltage output.
4. Can you connect the primary and secondary windings of a transformer in series without using two separate transformers?
No, you cannot connect the primary and secondary windings of a transformer in series without using two separate transformers. The winding ratio of a transformer is fixed, so you will need two transformers with different winding ratios to achieve the desired output voltage.
5. Are there any other ways to increase or decrease the voltage output of a transformer?
Yes, you can also use a voltage regulator or a transformer with a tap changer to adjust the voltage output. These methods allow for more precise control of the output voltage compared to connecting the primary and secondary windings in series.
  • Electrical Engineering
