Conservation Laws in Rotational Motion
  1. Apr 28, 2008 #1
    A uniform solid sphere, with diameter 28 cm and mass 2.5 kg, rolls without slipping on a horizontal surface, at constant speed of 2.0 m/s.
    1) What is the rotational kinetic energy?
    2) What is its total kinetic energy?
    3) What is its angular momentum?
    2. Relevant equations
    1) KE=1/2 Iw^2
    2) KE=1/2 Mv(cm) + 1/2*I(cm)*w^2
    3) L=Iw
    3. The attempt at a solution
    1) KE=1/2(2/5MR^2)(v/r)
    =1/2(19.6)(.14)
    =1.372
    2) KE=1/2 (2.5)(2.0)+ 1/2 (19.6)*(.14^2)
    =2.69
    3) L=(19.6)(.14)
    =2.744
    Does this solution look good? Thanks.
  3. Apr 28, 2008 #2
    [tex]KE_{linear} = \frac{1}{2} m v^{2}_{cm}[/tex]
  4. Apr 28, 2008 #3
    Did I forget the square on #2? Is that what you are saying? Thanks.
  5. Apr 28, 2008 #4
    alphysicist
    Hi Lma12684,
    Two things about 1): You did not square the (v/r) term; also, since you don't have units, I'm assuming that you want them in SI units. However, 19.6 is not correct for the moment of inertia. It's probably better to convert the radius to meters before you enter it in your calculator; or, if you wait until the end remember that there are two factor of centimeters in I, and you have to convert both of them to meters.
  6. Apr 28, 2008 #5
    Ok, I recalculated and found:
    1) 2 J
    2) 4.99 J
    3) 3.99 J
  7. Apr 28, 2008 #6
    alphysicist
    The first one looks right to me, but not the answers for #2 and #3. It's difficult to tell, though, since you haven't posted the numbers you used.
    For #2, was the 4.99 J for the total energy, or did you actually just calculate the translational kinetic energy? It looks like you may not have added the rotational KE to the translational KE.
    For #3, it won't have units of Joules. Also, did you perhaps (incorrectly) square the omega term?
  8. Apr 28, 2008 #7
    Here is what I did:
    2) KE=1/2MV(cm) + 1/2 I(cm)w^2
    =1/2(2.5)(2.0) + 1/2(.0196)(204.08)
    =4.99 J
    3) L=Iw
    =(.0196)(204.08)
    =3.99 J
  9. Apr 28, 2008 #8
    alphysicist
    In #2, you did not square the 2.0 for the speed in the translational kinetic energy.
    In #3, you can see from #2 that 204.08 is w^2, but here you need w.
  10. Apr 28, 2008 #9
    Thank You Again!!!!!!!!!!!!!
  11. Aug 27, 2009 #10
    Since it is a sphere then the moment of inertia is
    I = 2/5mr^2
    so the equations I used for a,b, and c are:
    a) KE = (1/2)(2/5mr^2)(v^2/r^2) = 2.0J
    b) KE = 1/2mv^2 + 1/2Iw^2 = 5.0J + 2.0J = 7.0J
    c) L = Iw = 4.0 kg*m^2/s
    I think this is right, what do you think?
    also, w^2 = (v^2/r^2) so the radius cancels out and I didn't have to use r = 0.14 m
Similar Discussions: Conservation Laws in Rotational Motion
Loading...
