Conservation of Energy in different inertial frames
In summary: KE is a scalar, but it is a SCALAR PRODUCT. That's why you have to include the direction of the vector (i.e. the direction of the motion).This is not a matter of opinion. I'm a physicist and I'm telling you that you need the direction here. The direction is included in the definition of the vector. QED.Pete,...the problem is that the KE is a scalar, but it is a SCALAR PRODUCT. That's why you have to include the direction of the vector (i.e. the direction of the motion).This is not a matter of opinion. I'm a physicist and I'm telling you that you need the direction
bartieshaw
50
today my dynamics lecturer illustrated a situation to us where energy did not appear to be conserved.
The situation involves observing the motion of a mass sliding down a slope, height 'h' above the ground from rest
initially in the rest frame, we see;
initially,
PE = mgh
KE = 0
as the mass starts from rest (we are assuming the force required to start the motion of the mass is insignificant)
and finally (at the bottom of the slope),
PE = 0
KE = 1/2 mv^2
NB. i cannot work out how to make a diagram and post it, but imagine the mass is sliding down the slope to the right.
using this we can claculate the simple equation to determine the final velocity of the mass (to the right)
v = (2gh)^(1/2)
This was simple to comprehend, but now our lecturer asked us to imagine observing the motion from another inertial frame moving to the right (relative to the rest frame) at velocity, v = (2gh)^(1/2)
when drawing this, we see the mass now appears to initially be be moving to the left with velovity, v = (2gh)^(1/2), and when the mass reaches its maximum velocity (v = (2gh)^(1/2) to the right) at the bottom, the mass appears to be at rest.
thus when observing from this frame we see the following occurring
initially
PE = mgh
KE = 1/2 mv^2 = mgh
hence, initial energy, E=2mgh
PE = 0
KE = 0
this obviously seems to disagree with the conservation of energy and I am sure there is something wrong with what i have described, but i simply do not know
can anyone explain what is really going on here...?
Actually this is not an issue of the conservation of energy. This is an issue known as invariance. Energy is always conserved, but it is not invariant meaning that depending on your frame of reference you will measure it differently. Any object traveling at the same velocity as you will appear to have no kinetic energy right? But you will find that whatever reference frame you use, the conservation laws will hold. When you step into the realm of relativity you will also find other quantities:
mass: not conserved but invariant
charge: conserved and invariant
velocity: neither conserved nor invariant
Your instructor is just pulling your leg.
initially
PE = mgh
KE = 1/2 mv^2 = mgh
You must include the KE energy of the Earth, since it's moving in this frame.
PE = 0
KE = 0
Figure out the work done on the Earth during the ball's motion. You'll find that the work done on the Earth will exactly equal the missing energy. Energy is conserved!
(Hint: How far does the Earth move during the time that the ball falls? Realize that the average horizontal speed of the ball is only v/2, so that the Earth moves twice as far as the ball.)
i don't understand...
bartieshaw...
do u understand?
Yeah, i do now, thank you for answering
Still unsure
I sort of understand what you are saying, but can't seem to be prove it...?
So which is right? Is the statement that energy is invariant correct, or is it right to say energy is conserved even during changing frames?
Is energy invariant or not?
Also, why is it called invariant? Doesn't that mean in does not vary??
Huh? Who said energy was invariant?
Yes, energy is conserved in either frame.
n/m. nobody said it was invariant. :p I was lacking sleep when I wrote that.
initially
PE = mgh
KE = 1/2 mv^2 = mgh
PE = 0
KE = 0
There's your mistake. Should be [tex]KE = -1/2 mv^2[/tex]. KE has a vector, and at the start of the experiment, it is opposite to your "moving" reference frame.
  • Skeptical
Likes Dale
KE is a scalar, not a vector!
Likes Dale
How so, given the velocity term?PS: (im not arguing with your statement, i think i know why, i just can't be sure :P)
Because the velocity term appears in the expression for KE within a scalar product:
[tex]T = \frac{m|\vec{v}|^2}{2} = \frac{m\vec{v}\cdot\vec{v}}{2}[/tex]
i.e. it's the length squared. It's the only way to turn a pair of vectors into a scalar - by the scalar/inner (sometimes known as dot) product. And by definition, the inner product of two vectors is equal to or greater than 0 (the equality holding for the zero vector only).
So confused?
:confused: Can someone please clarify this? What is actually happening? Thanks
Look at it this way, change the math the way I suggested and the mystery disappears.
Kinetic Energy is the result of motion which has a vector. You cannot ignore the direction the force is applied in and expect the OP situation to make any mathematical sense.
  • Skeptical
Likes Dale
It only appears to. The math as suggested by you is wrong...and it wouldn't work for any other velocity of the reference frame (w.r. to the Earth frame).
The KE itself is a scalar and the situation makes perfect mathematical sense if you do the math right.
Pete, see post #3.
Likes Dale
Work Done on the Earth?
Ok I understand the concept now. So with the addition of the work done by the Earth energy is conserved. But how do I find the work done on the Earth so that I can prove that energy has been conserved?...
To properly account for the KE, you must consider all the forces acting. In particular, the sliding mass and slope exert forces on each other.
In the usual frame of reference, where the slope is stationary, this contact force--the normal force--does no work.
But viewed from a moving frame, the slope moves and thus "work" is being done by those forces on the slope and on the mass. Since they move at different speeds, the work done on each is not the same. But the net change in KE of all objects (earth and sliding mass) will exactly balance the change in gravitational PE.
Proof that changing the refererence inertial frame doesn't change the truth of energy conservation:
First, we have the "rest frame", the frame where we accept the truths of momentum and energy conservation (for the problem in the OP, this is the Earth frame). In this frame,
[tex]P_0 = \sum m_iv_i = const [/tex]
[tex]E_0 = (1/2)\sum m_iv_i^2 + \sum U_i = const [/tex]
Now consider a frame moving a speed v (v<<c), relative to this frame. In the new frame,
[tex]E_v = (1/2)\sum m_i(v_i-v)^2 + \sum U_i = E_0 - (1/2)\sum m_iv_i^2 + (1/2)\sum m_i(v_i-v)^2 = E_0 - 2vP + (1/2)\sum m_iv^2 [/tex]
All the terms in the RHS are constants, and hence, the total energy is conserved in the new frame as well.
Note: All squares and products of velocities (or velocities with momenta) are to be understood as scalar (dot or inner) products.
Excellent, Gokul. That's the easiest way to convince oneself that energy is conserved in all frames, since it avoids having to consider the details of the forces involved.
1. What is the concept of conservation of energy in different inertial frames?
The concept of conservation of energy states that energy cannot be created or destroyed, it can only be converted from one form to another. In different inertial frames, this principle holds true as the total energy of a system remains constant regardless of its position or motion.
2. How does the conservation of energy apply to different inertial frames?
In different inertial frames, the total energy of a system may appear to change due to the relative motion between the frames. However, when all forms of energy (potential, kinetic, and rest energy) are considered, the total energy remains the same in all inertial frames.
3. How does the concept of frame of reference relate to conservation of energy?
The concept of frame of reference is important in understanding conservation of energy in different inertial frames. The laws of physics, including conservation of energy, hold true in all inertial frames, but the observations of energy may differ depending on the frame of reference.
4. Can the conservation of energy be violated in different inertial frames?
No, the conservation of energy is a fundamental law of physics and cannot be violated in any inertial frame. However, the observations of energy may differ depending on the frame of reference, leading to the misconception that conservation of energy is violated.
5. What are some real-life examples of conservation of energy in different inertial frames?
One example is the motion of a pendulum. In one frame of reference, the pendulum swings back and forth with potential and kinetic energy. In a different frame of reference, the pendulum may appear to have a circular motion with only kinetic energy. However, the total energy remains the same in both frames. Another example is a moving car, where the kinetic energy appears to increase in a stationary frame but remains constant in a moving frame.
  • Mechanics
  • Mechanics
  • Mechanics
  • Mechanics
  • Mechanics
