Conservation of Energy Physics Olympiad
In summary: That's the key.In summary, a ball of mass M and radius R, with a moment of inertia of I = 2/5MR, is released from rest and rolls down a ramp with no frictional loss of energy. It is then projected vertically upward on a ramp, reaching a maximum height ymax above the point where it leaves the ramp. To determine ymax in terms of h, you can use the equation PE = 1/2mv^2 and rotational KE = 1/2I omega^2, and recognize that the ball rotates once in the same time that it rolls a distance 2 Pi R meters. By equating the PE at the start to the KE + rotational energy on the level, a direct proportion
bazookajason
A ball of mass M and radius R has a moment of inertia of I =2/5MR. The ball is released from rest and rolls
down the ramp with no frictional loss of energy. The ball is projected vertically upward o a ramp as shown in
the diagram, reaching a maximum height ymax above the point where it leaves the ramp. Determine the maximum
height of the projectile ymax in terms of h
The image is cut off but h is the height from the top of the ramp to the ball
PE=1/2mv^2
Rotational KE= 1/2 I omega^2
KE= 1/2mv^2
Using x as the distance between the bottom and top of the ramp:
mg(h+x) = 1/2mv^2+1/2I omega^2 =1/2mv^2 + 1/2(2/5mr^2)omega^2 = 1/2mv^2 + 1/5mv^2 = 7/10mv^2
7/10mv^2=mgx + 1/2mv'^2
1/2mv'^2 = ymax
im stuck here D: any hints?
Okay so physically the ball rolls down and then exits the ramp spinning and going upward a certain height.
It's energy initially is mgh right? And it's energy afterward will be in the spin and in its motion so if you can determine its rotational energy and subtract it from the mgh you'd have a new mgh right from which to get the final height.
Does that sound right?
its energy initally should be mg(h+x), because mgh is just the energy from the top of the ramp to the inital position of the ball
I'm not sure why you introduced an x. It rolls from an initial vertical height h, and rises to a height ymax.
Don't you need an equation to relate the omega to the ball rolling down with no friction and no slipping? Also do you need the angle of the ramp or does that fall out somewhere? If not I suppose you could choose say 60 degrees or better yet use a variable for it.
The clue that is the key to problems like this is to recognize that, by descending without slippage, the rotational speed of the ball is directly related to its linear velocity. When you think about it, it seems obvious, though it may still help if it's spelled out: the ball rotates once in the same time that it rolls a distance 2 Pi R metres.
While you may think the angle of the ramp is needed, it seems not. During the descent, the gravitational potential energy of the ball is totally converted into linear and rotational energy.
Sure, however, that still leaves many unknowns. Including the velocity at the bottom and the max y.
By equating PE at start to KE + rotational energy on the level, I was able to then obtain a direct proportionality between ymax and h. Recognize that as it rises, the KE is converted into PE while the rotational energy remains as rotational energy.
1. What is the Conservation of Energy?
The Conservation of Energy is a fundamental law in physics that states that energy cannot be created or destroyed, only transformed from one form to another. This means that the total amount of energy in a closed system remains constant over time.
2. How is the Conservation of Energy relevant to the Physics Olympiad?
The Conservation of Energy is a key concept in physics that is often tested in the Physics Olympiad. It is important for students to understand and apply this law in various scenarios, such as calculating the energy of a system or analyzing energy transformations.
3. Can you give an example of the Conservation of Energy in action?
One example of the Conservation of Energy is a swinging pendulum. As the pendulum swings back and forth, its potential energy is converted into kinetic energy and then back into potential energy. The total amount of energy remains constant throughout the motion.
4. What are some common misconceptions about the Conservation of Energy?
One common misconception is that energy can be created or destroyed. Another is that energy can only exist in the form of motion or physical objects. In reality, energy can take many forms, such as heat, light, or chemical energy.
5. How can I prepare for questions related to the Conservation of Energy in the Physics Olympiad?
To prepare for questions on the Conservation of Energy, it is important to have a strong understanding of the law and be able to apply it in different situations. Practice solving problems and familiarize yourself with various energy forms and equations. Also, make sure to review any relevant concepts and definitions before the exam.
