Understanding Lepton Number Conservation in Particle Interactions
In summary, the conservation of lepton number is composed of different sorts of lepton number, L_{\mu}, L_{\tau}, and L_{e}, which are conserved in all interactions. However, the lepton number for anti-particles is negative. Despite the confusion about the conservation of lepton number in the muon decay, it is actually conserved as the initial and final values are both zero. The relationship between lepton number conservation and neutrino mass is still being studied, and there is currently no evidence for neutrino oscillations without mass.
Radiohannah
49
Hello there!
May I ask:
I am learning about the conservation of lepton number. I understand that the lepton number is composed of different sorts of lepton number,
[tex] L_{\mu}[/tex] and [tex]L_{\tau}[/tex] and [tex]L_{e}[/tex].
And these are conserved in all interactions.
I am confused however about the lepton number for anti-particles. Are the lepton numbers negative for anti-particles?
Because in the muon decay;
[tex] \mu^{-} \rightarrow e^{-} + \overline{\nu_{e}} + \nu_{\mu}[/tex]
I can see that [tex]L_{\tau}[/tex] is conserved (0) and [tex] L_{\mu}[/tex] is conserved, but [tex]e^{-}[/tex] would have [tex]L_{e}=1[/tex] and then [tex]\overline{\nu_{e}}[/tex] would have [tex]L_{e}= -1[/tex] which isn't conserved.
:-S
Cheers
Yes.
Probably not directly relevant here, but I believe they're not actually perfectly conserved, and this is related to the fact that neutrinos have mass.
It is conserved in this decay. The initial value of [tex]L_e[/tex] is zero, and so is the final value (+1-1=0).
Aaaaah!
It's 0 to begin with! Woops! I see.
Thanks! :-)
It is relevant if lepton number is not always conserved.
The electron lepton family has mass and yet for these (e,mu,tau) massed particles, lepton number is always conserved.
So is it really because the neutrino has mass?
There is a difference between saying only if neutrinos have mass is there the possibility that they can change from one family member to another, and saying its because they have mass.
As far as I know, all neutrino measurements where the neutrino changes generation also involves the neutrino going through matter (which may be true source of the generational neutrino fluctuation/change and potentially lepton number is actually conserved).
If there is a neutrino experiment involving generational change measurement that doesn't travel through matter, please give me the reference.
Of course, even if you want to be pedantic, no one in this thread ever said "its [sic] because they have mass". Yes, it would certainly be theoretically possible for neutrinos to have a mass and not oscillate or violate lepton number. On the other hand, a neutrino mass is necessary for these effects (which have been observed), which is quite accurately described by the statement "they're not actually perfectly conserved, and this is related to the fact that neutrinos have mass". An open question is whether total lepton number conservation can be violated (as in a neutrinoless double beta decay process, which is only possible if they are majorana particles), rather than just violation of individual lepton family which is violated in neutrino oscillations (e.g., electron number, muon number, etc). All of this requires a non-zero neutrino mass, however.
That's quite a tall order you've got there. I think it makes more sense for you to first explain how it would be possible to have neutrino oscillations with all massless neutrinos--in either matter or vacuum. I'm certainly no expert, but I don't see how that would be possible.
**Edit: I just realized my response probably came off as exceedingly snarky. I apologize for that, but I would appreciate it if you could back up your claim that lepton number might actually be conserved. **
Btw, no mass implies no oscillation is very simple: if there's no mass, then they travel at the speed of light, and so there's no passing of proper time, and so literally no time to oscillate in.
What is the conservation of lepton number?
The conservation of lepton number is a fundamental principle in particle physics that states that the total number of leptons (such as electrons, muons, and neutrinos) must remain constant in any interaction or decay process.
Why is the conservation of lepton number important?
The conservation of lepton number is important because it is a fundamental law of nature that governs interactions between particles. It helps us understand and predict the behavior of particles and their interactions.
How is the conservation of lepton number related to other conservation laws?
The conservation of lepton number is related to other conservation laws, such as the conservation of energy and the conservation of momentum. These laws work together to ensure that the fundamental properties of particles, such as their mass and charge, are conserved in all interactions.
What happens when the conservation of lepton number is violated?
If the conservation of lepton number is violated, it would mean that some interactions or decays would result in a change in the total number of leptons. This would be a violation of a fundamental law of nature and would require a new theory to explain it.
Is the conservation of lepton number always obeyed?
So far, the conservation of lepton number has been observed to hold true in all experiments and observations. However, some theories, such as certain extensions of the Standard Model, allow for the violation of lepton number conservation in certain rare processes. These theories are still being tested and studied.
