Why Water Decreases in Cross-Sxn Area: Conservation of Mass
In summary, when water falls from a faucet, it experiences a decrease in cross sectional area due to the conservation of energy. This is because the water further away from the faucet has been falling for a longer duration and has a higher velocity. Even in a vacuum, the cross sectional area would decrease due to gravity and surface tension. This is also explained by the laws of fluid mechanics and intermolecular interactions.
quasi426
208
Why does water bottleneck or decrease in cross sectional area when it falls from the faucet. The book says it is conservation of mass stuff...
(Cross-Sxn Area)* (velocity) = constant.
How can that be if all the water is accelerating at the same pace. What I mean is that all the water in the cross sectional area at the start should be increasing in velocity at the same rate due to gravity.
This is absolutely true. But the water further away from the faucet has been falling for a longer duration and has a higher velocity.
Bear with me; per second, the amount (volume) of water that passes through the hole is equal to the amount that falls onto the sink, right? Otherwise there would be some kind of water buildup in between. If the 'water beam' were to have constant cross-section, there would be less water exiting the faucet than what fell on the ground: imagine the velocity of the water is 1m/s at the faucet, and 10m/s just before hitting the surface underneath. Then, in 1 second, one meter of 'beam' will have past through the faucet, and, in that same second, 10 meters of beam will have hit the surface. Because the volume of either is the same, the cross section must have decreased. Hope that clears things up.
Would the cross section of the water decrease towards the bottom if it was in a vacuum?
Yes it would. A vacuum is not the issue here, it is gravity. Gravity accelerates the stream of water.
quasi:
Consider the inverted case, with a fountain:
Do you agree that the cross-section of the spurt INCREASES until you get to the top where the water starts falling down again?
Just a couple of points I thought I'd throw in. First off, the pertinent law is the conservation of energy, not mass. As gravitational potential energy is converted into kinetic energy, and the longer any given water molecule has been accelerated the faster it must be falling, then on average a molecule nearer the sink than the tap will be traveling faster than one nearer the tap than the sink. If you take any given area, say a cubic centimetre, the molecules at the top of that area also must be moving slower than those at the bottom, so the water is kind of being stretched out vertically. This in itself does not necessitate that the cross-sectional area must decrease. If this were the only concern, the cross-sectional areas may be the same at the top as the bottom, but the density would be greater at the top. What makes the cross-sectional area decrease, rather than the density, is (on a fundamental level) the intermolecular interactions between the water molecules. For the density to decrease, the average distance between molecules has to to increase, meaning an increase in potential energy. This requires an increase in temperature, but no heat is being transferred to the water (bar the negligible friction with this air, and not even that in a vacuum). Therefore the average distance between molecules has to be constant, and so it is the cross-sectional area that has to decrease. This is explained macroscopically by the laws of fluid mechanics, involving field lines and viscosity and other things I can't remember much about.
Yes. Surface tension holds the stream together. (As Fred says, vacuum is not the issue.)
1. Why does water decrease in cross-sectional area?
Water decreases in cross-sectional area due to the principle of conservation of mass, which states that mass cannot be created or destroyed, only transferred or transformed. When water flows through a smaller cross-sectional area, the same amount of water must pass through in a shorter amount of time. This results in a higher velocity, which causes the water to spread out and decrease in cross-sectional area.
2. How does the principle of conservation of mass apply to water?
The principle of conservation of mass applies to water because it is a fundamental law of physics that applies to all matter, including liquids like water. This means that the total mass of water in a closed system remains constant, and any changes in mass must be accounted for through transfer or transformation.
3. Is it true that water always decreases in cross-sectional area?
No, it is not always true that water decreases in cross-sectional area. The decrease in cross-sectional area only occurs when the flow of water is constricted or forced through a smaller space, such as in a river or pipe. In other situations, such as when water is flowing freely over a wide area, the cross-sectional area may remain constant.
4. How does the decrease in cross-sectional area affect the flow of water?
The decrease in cross-sectional area can significantly affect the flow of water. As the cross-sectional area decreases, the water must flow faster to maintain a constant flow rate. This increase in velocity can create turbulent flow, which can cause erosion and other changes to the surrounding environment.
5. Are there any exceptions to the principle of conservation of mass for water?
No, there are no exceptions to the principle of conservation of mass for water. This principle is a fundamental law of physics that applies to all matter, including water. Any apparent changes in mass are due to transfer or transformation, but the total mass of water always remains constant in a closed system.
  • Mechanics
  • Mechanics
  • General Engineering
  • Mechanics
