Homework Help: Conservation of momentum and energy
  1. Oct 19, 2009 #1
    a) At t=1 second, a 0.5 kg cart is at x=0.5 m, traveling at 0.5 m/s. At t=3 seconds, the cart is
    at 1.4 m, traveling at 0.4 m/s. What is the acceleration due to friction, the frictional force and
    the work done by friction? What is the change in kinetic energy of the cart?
    b) If a cart of mass 0.6 kg, traveling a 0.5 m/s collides elastically with a cart of mass 0.4 kg,
    initially at rest, what is the final velocity of the first cart?
    c) If the two carts above stick together after the collision, what is the final velocity of the first
    cart?
    d) What is the final velocity of the first cart in (b) if the second cart has mass 1.5 kg?
    e) What is the final velocity of the first cart in (c) if the second cart has mass 1.5 kg?
    2. Relevant equations
    Elastic collison formula
    Inelastic collision
    Impulse
    W=-FD
    Change in kinetic energy formula
    3. The attempt at a solution
    ok here is my attempt. I need someone to check if Im using the right equation for each problem.
    part a)
    i used vf^2-vi^2 = 2ad
    to get an acceleration of .05
    To find the firctional force i used
    F = -ma F= (.5)(.05)
    Ff = -.025N
    W = -Fd
    W =-(-.025)(.05)
    W = 0.0125J
    change in ke
    Ke =1/2mvf^2-1/2mvi^2
    KE=1/2(.5)(0.5)^2-.5(0.5)(0.4)^2
    Kef = .0225
    part b)
    v1f = vi*(m1-m2)/(m1+m2)
    0.5*(0.6-0.4)/(0.6+0.4)
    v1f=0.1m/s
    part c)
    v1f = vi*(m1)/(m1+m2)
    (0.5)(.6)/(0.6+0.4)
    v1f=0.3m/s
    part d
    0.5*(0.6-1.5)/(0.6+1.5)
    v1f=0.2143m/s
    part e
    (0.5)(.6)/(0.6+1.5)
    v1f=0.143m/s
Draft saved Draft deleted
