Conservation of Momentum of a body of mass
In summary, a collision between two bodies of equal mass, where one is initially stationary and the other has a velocity u, will result in the two bodies sticking together and moving at a new velocity of 1/2 u. This is due to the conservation of momentum, where the total momentum before and after the collision remains the same. However, the collision is not elastic and results in a loss of kinetic energy, with only 1/4 of the initial energy remaining. Therefore, the collision does not conserve kinetic energy, but does conserve total energy.
Eugbug
If a body of mass m and velocity u collides with another body of mass m which is stationary,
and then the two bodies move off together, then conservation of momentum suggests that the since the combined mass is 2m, the new velocity will be 1/2 u.
Total momentum before collision = mu + m0 = mu
Total momentum after collision = m(1/2u) + m(1/2u) = mu
However energy before collision = 1/2mu2
and energy after collision = 1/2m(1/2u)2 + 1/2m(1/2u)2 = 1/4mu2
So it seems the energy is halved or am I making an error in the calculations ?
If, as you say, the object stick together after collision, then indeed kinetic energy is lost. The energy has gone to internal energy of the colliding masses. A collision where the objects move away together is NOT elastic. In an elastic collision (one that does conserve kinetic energy) with two equal masses, one of which is stationary, the incoming object will hit the stationary one and come to rest while the stationary object moves off at a speed equal to that of the incoming object.
some info and nice graphics: http://en.wikipedia.org/wiki/Elastic_collision
Does conservation of momentum only take place with elastic collisions ? If the collision is inelastic and the masses stick together, the combined mass is 2m so to conserve momentum, the velocity would be half and energy after collision = 1/4mu2 or exactly half the energy before the collision.
Eugbug said:
Does conservation of momentum only take place with elastic collisions?
From your OP you seem to understand the difference between energy and momentum, so I think you make a typo there.
ENERGY is only conserved with perfectly elastic collisions. In fact that's the definition of what a perfectly elastic collision is. There are no PERFECTLY elastic collisions in real life.
MOMENTUM is always conserved, in any sort of collision, because the forces acting on the two objects are always equal and opposite to each other.
Not trying to be picky, but ENERGY is always conserved too. It is just not conserved as KINETIC energy.
AM
Likes gracy
Going back to the original example, the body with velocity u and mass m strikes the stationary body of mass m. The collision is inelastic and the bodies stick together.
Am I correct that in saying that the total momentum before the collision is mu and after the collision (2m)(1/2u) = mu and energy before collision is 1/2mu2 and after collision 1/2(2m)(1/2u)2 or 1/4mu2 ? Does exactly half of the energy remain as kinetic energy ?
On those facts, yes. In the centre of mass frame, both masses are approaching the centre of mass at speed u/2. The energy before the collision is 2 x .5m(u/2)^2 = mu^2/4 and after the collision it is 0.
AM
Total momentum after collision = m(1/2u) + m(1/2u) = mu = MV
where M = 2m and V = u/2 are mass and velocity of the composite body.
energy after collision = 1/4mu2 = 1/2 2m (u/2)2 = 1/2 MV2
Everything is right.
What happens is that your collision is not elastic and does not conserve kinetic energy (total energy is still conserved). It can be showed that for a system of particles with the same mass, an elastic collision interchange the velocities. That is your stationary particle would acquire velocity u and the moving particle would stop. This is not the case which mean that your collision is not elastic
1. What is the definition of conservation of momentum?
Conservation of momentum is a fundamental principle in physics that states that the total momentum of a closed system remains constant or is conserved over time. This means that the total momentum before an event or interaction is equal to the total momentum after the event or interaction.
2. Why is conservation of momentum important?
Conservation of momentum is important because it is a fundamental law of physics that governs the behavior of objects and particles in motion. It can be used to predict the outcomes of collisions, explosions, and other interactions between objects, and it is crucial in understanding the motion of systems in space.
3. How is conservation of momentum related to Newton's laws of motion?
Conservation of momentum is derived from Newton's laws of motion, specifically the law of conservation of energy. This law states that momentum cannot be created or destroyed, only transferred from one object to another. Newton's third law, which states that for every action there is an equal and opposite reaction, is also closely related to the concept of conservation of momentum.
4. What are some real-life examples of conservation of momentum?
One example of conservation of momentum is when a skateboarder pushes off a wall to gain momentum in the opposite direction. Another example is when a rocket launches into space, the exhaust gases create an equal and opposite force on the rocket, propelling it forward. In both cases, the total momentum of the system remains constant.
5. How can conservation of momentum be applied in engineering and technology?
Conservation of momentum is used in many engineering and technological applications, such as designing efficient rockets and spacecraft, creating safer car airbags, and improving the performance of sports equipment. It is also crucial in understanding the behavior of fluids and gases in various systems, such as in turbines and pumps.
  • Mechanics
