What is the angular displacement of a wheel with constant angular acceleration?
In summary, the problem involves finding the angular displacement of a wheel undergoing constant angular acceleration starting from rest at t=0s and continuing until t=19s, when the acceleration abruptly changes to 0 rad/s^2. The angular velocity at t=3.9s is given as 6.9 rad/s. By using the equations ω=ωo+αt and θ = ωot + (1/2)αt^2, the angular acceleration is found to be 1.77 rad/s^2. The angular displacement for the first time interval (t=0s to t=19s) is then calculated as 319.485 rad. For the second time interval (t=
delecticious
65
Starting from rest at t = 0s, a wheel undergoes a constant angular acceleration. When t = 3.9s, the angular velocity of the wheel is 6.9 rad/s. The acceleration continues until t = 19s, when the acceleration abruptly changes to 0 rad/s^2. Through what angle does the wheel rotate in the interval t= 0s to t= 43s?
ω = ωo + αt
θ = ωot + (1/2)αt^2
θ = 1/2(ωo +ω)t
First I found the the angular acceleration using the initial angular velocity. That much I'm sure is right, the rest is where I am having difficulty. I know you have to find theta for each of the different time intervals, but I'm not sure I using the right equations and thus getting the right answers. Anyone willing to help?
First find the angular displacement of the first interval is. θ(0->19) (second equation you listed, ωo = 0)
Then find the angular velocity at the end of the first interval ω(0->19) (first equation you listed, ωo=0).
Then find the angular displacement of the second interval θ(19-43) (second equation, ωo=ω(0->19) )
Now add θ(0->19) and θ(19-43)
what about the 3.9s?
or is the 3.9s only needed to find the angular acceleration of the first interval?
Yup, only needed to find the constant angular acceleration in the first interval.
I'm confused about one thing. It says at 3.9s angular velocity = 6.9 rad/s, shouldn't that quantity come into play at some time? And also in the last step of the explanation you gave where you say the initial and final angular velocities are equal do you mean the angular velocity I found in the previous step or the given angular velocity?
Only to determine the angular acceleration during the first interval:
[tex]\alpha=\frac{6.9 rad/s}{3.9s}[/tex]
I ended up getting a pretty big number, but I'm not sure if it's right, I got 1636 approximately for my final answer, could you possibly double check for me?
never mind I just checked it's not right
I got something that was a few hundred less than your answer (can't just give it to you :) ) Make sure you're only calculating the constant angular velocity part for a time of (43-19) seconds.
I've tried everything and I just can't get this right, so I'll walk you through my math step by step. First I found the angular acceleration by dividing the 6.9 by 3.9 and got 1.77 rad/s^2.
First check point, is my angular acceleration right? I think it is but if isn't let me know.
Second I did what you said and found the angular velocity at the end of the first interval by multiplying the angular acceleration times the time of 19 seconds since the initial velocity is zero. I got 33.63 from that. Is that right?
Third I found the angular displacement over the 19 second time interval by multiplying 1/2 times 1.77 times 19^2 and got 319.485. Is that right?
Fourth I found the angular displacement over the second time interval (24 s) by multiplying 33.63 times 24 and adding that quantity to 1/2 times 1.77 times 24^2 and got the number 1636, which is obviously wrong so at what point did I go wrong?
anyone still willing to help me out?
Don't forget that when you're calculating the angular displacement for the 2nd time interval, that the acceleration is 0. so your equation should be:
θ(19-43) = θ = ωot
You should get the correct value now after adding the two angular displacements together.
What is constant angular acceleration?
Constant angular acceleration refers to the rate of change of angular velocity over time, where the acceleration remains constant. It is a measure of how quickly an object's rotational speed is changing.
How is constant angular acceleration calculated?
Constant angular acceleration is calculated by dividing the change in angular velocity by the change in time. The unit of measurement for constant angular acceleration is radians per second squared (rad/s²).
What is the difference between linear and angular acceleration?
Linear acceleration is the rate of change of an object's velocity in a straight line, while angular acceleration is the rate of change of an object's rotational velocity about an axis. Linear acceleration is measured in meters per second squared (m/s²) while angular acceleration is measured in radians per second squared (rad/s²).
What are some real-life examples of constant angular acceleration?
A spinning top, a rotating fan, and a Ferris wheel are all examples of objects experiencing constant angular acceleration. These objects have a constant rate of change of their rotational speed over time.
How does constant angular acceleration affect an object's motion?
Constant angular acceleration causes an object to experience a change in its rotational velocity, either increasing or decreasing its rotational speed. This can also cause a change in the object's angular position over time. Objects with constant angular acceleration will have a linear relationship between angular acceleration and time.
