- #106
jim hardy
Dearly Missed
- 9,832
- 4,894
How hot is the mosfet to touch? To be technical, does it "fry spit" ?Lexilighty said:right not pin 2 to GND is 0.288V when pin 3 to GND is 1.652V (RIO is also 1.652V). I have probably lost the opamp. I also get a very hot valve afterwards.
0.288 volts/7.4ohms = only 0.038 amps , so if excessive current is going through valve it isn't making it to R1.
Might you put DMM set for ammeter in series with valve ?
and with R1 of only 7.4 ohms
wouldn't 165 ma give voltage of 1.221 ?
Indulge my curiosity
RIO calling for 1.221
meter negative on your AGND where they all tie together (at RIO?)
read
Volts at OUT/bottom of solenoid valve =
Volts at top of R1 =
Volts at opamp pin2 (-in)=
millivolts at physical bottom of R1 = not at RIOgnd, am looking to measure millivolts along the wire from R1 to AGND
millivolts at 0V side of 24 volt supply = right at the supply not at RIO gnd same reason looking for millivolts along that wire
millivolts at opamp V- terminal pin11 = right at opamp same reason
All readings wrt your circuit common tie point.
